TPI/rails/MAF/Dissy/TB/etc
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
A buddy of mine owes me some money so he gave me this TPI set up out of a running '88 I-ROCK w/ 5.7.
The set-up should be pretty much complete minus the ECM and wiring harness:
intake, runners (very good condition), plenum.
Stock throttle body with TPS and IAC sensors
Descreened stock MAF and factory bellow.
rail w/ 5.7 injectors (has 9th injector)
Should have all other misc sensors that plug into the manifold
Stock Dissy (no cap or rotor though).
The only things wrong with this unit are:
needs new runner gaskets
One of the fuel lines running to the rail needs replaced as it managed to get get crimped. It is not on the rail it's self, but on that runs up to the rail. Should be easily replacable or repaired.
Unit is dirty/needs cleaning. I will clean it and post pics after memorial day.
I have no clue what this set up would go for - a quick browse looks like around $200 plus shipping, so that is what I will list it for.
Located aboat an hour s/w of chicago if anyones interested in picking it up
Thankl you for looking
Engine: LO3;383tpi
Re: TPI/rails/MAF/Dissy/TB/etc
This was pulled because the car is being converted to an all out drag car with a solid roller 383 with 7.5K rpm shift points
Engine: LO3;383tpi
$100 This needs to go
