[MO] 355 SBC motor fresh! Alum heads built nice!
Old Jul 14, 2009 | 09:51 PM
jwilliams417's Avatar
Located in Southwest Missouri. Built 355 SBC with no miles on her at all. 91 L98 block was used for the build. Block was tanked and baked, bored 030 over, and decked. Speed Pro Flat top pistons, moly rings. Eagle crank, rods, clevite bearings, ARP hardware throughout. Melling Hi volume oil pump, LT4 Hotcam .525 .525 219/228, cloyes billet double roller timing set. Pro Street balancer. Fel Pro gaskets. That pretty well sums up the bottom end. All new high quality parts.
Top end has Patriot Performance 190 Aluminum heads with double springs (handle .575 lift), screw in studs, guideplates, 64cc, accessory holes drilled
ProForm 1.6 roller rockers
Pro Products RPM high rise polished intake
Comp roller lifters
Heddman Jet hot coated long tubes
$2200
Attached Thumbnails [MO] 355 SBC motor fresh! Alum heads built nice!-motor2.jpg   [MO] 355 SBC motor fresh! Alum heads built nice!-motor4.jpg
Old Jul 15, 2009 | 11:20 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: [MO] 355 SBC motor fresh! Alum heads built nice!
Sorry, but would I be able to throw a HSR on this. If i'm correct patriout heads are vortec style right? What power was this engine dynoed at?
Old Jul 15, 2009 | 11:33 AM
No these are not vortec style heads and will except a HSR as long as it is the revised HSR that was manufactured after november 2007 with the extra material added on the ports.
Old Jul 15, 2009 | 02:41 PM
ssgtgaines's Avatar
Car: 86 firebird
Engine: 385 dart pro 1 heads 13 to 1
Transmission: th350 4800 stall
Axle/Gears: 33 spline nine inch
will you separate the headers and if so how much.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
