383 Stroker SBC
Old Jul 15, 2009 | 07:14 AM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
383 Stroker SBC
383 Stroker
• 4.040" bore 10.1:1 compression
• Eagle Cast Steel 3.750" Stroker Crank
• Reconditioned 5.7" Rods
• SRP Flat Top Forged Pistons 10.1:1 Compression
• JE Pro Seal Piston Rings
• Trickflow Hydraulic Flat Tappet Cam, Advertised Duration 308/316, Lift .495/.510, 112 Lobe
• Trickflow Billet Steel Double Roller Timing Chain
• Trickflow Hydraulic Flat Tappet Lifters
• Trickflow Heads, CNC 23 Degree, Aluminum, 72cc Chamber, 195cc Intake Runner
• Trickflow Chromemoly Pushrods 5/16" Diameter, 7.850" Length
• Trickflow 1.5 Aluminum Roller Rockers 3/8"
• Edelbrock Victor Jr Intake Single Plane 3500-8000rpm
• Moroso 7 Quart Oil Pan
• Summit High Volume Oil Pump
• ATI Balancer
I also have brand new stud girdles that i havent put on the motor yet
been 11.2 on motor in a 3300lbs Camaro
9.70 on a 250 shot nos tune.
awesome street motor. only 10.1 compression. PUMP GAS
$3800
Old Jul 15, 2009 | 07:11 PM
doug9126's Avatar
Want a title? Post!
Re: 383 Stroker SBC
what is the hp rating
Old Jul 15, 2009 | 08:10 PM
Iroc Adio's Avatar
Car: 1987 IROC
Re: 383 Stroker SBC
should make around 500hp on motor
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
