LT1 SWAP POWER STEERING LINES
Old Aug 11, 2009 | 05:13 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Is anyone interested in power steering lines?
I will be making myself a set in the next couple of days for my own swap and will make a few sets if anyone is interested.
They will be made of 5000 PSI Hydaulic Hose with a 90 end on the power steering box side and a straight end on the pump side. Will be made with 3/8 hose which is the same size as 6an. You will need the two adapters that thread into the power steering box and pump to connect these lines. I can make likned with the proper o-ring fitting on the ends but would cost more.
Will do them for 40 buks a hose that is for a 5 foot long or 45 for a 6 foot.
I will post some pics up later. If there is anyinterest Lmk because I will not do this again just thought I would help out fellow third gen members.
Thanks, Josh
Old Aug 11, 2009 | 09:24 PM
net_coma's Avatar
Re: LT1 SWAP POWER STEERING LINES
where does this mount the resivoir?
Old Aug 12, 2009 | 06:15 AM
Factory mounting position. If you have the pump somewhere else Just measure the length of hose you need. I have acsess to hydaulic equipment to make the hoses at my shop.
LMK what you are after.
Josh
Old Aug 13, 2009 | 12:34 AM
ssean92's Avatar
Car: sold
Where were you when I was running PS. LOL
Old Aug 13, 2009 | 06:27 AM
The reervoir does not need any kind of pressure line. These lines I have made will work with the pump monted on the passeger side where it was mounted factory over to the powere steering box. I can make complete kits if someone wants. That would include all the adapters and hoses. All the work is done for you. I forgot to mention the hydarulic hose is also flame resistant.
We use these on all the big John Deere farm tractors and I have yet to see a failure.
I can make fuel lines as well. I will look into the best hose for that application but I can make what ever you guys need.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
