Some Performance Goodies
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Went in a different direction with my project and got some stuff left over. All parts have at most 5000 miles on em. Here's what i got
400 sbc centerforce EXTERNAL balanced flywheel...paid 307 brand new i'll let it go for 225 plus shipping obo
Bottom end kit...Eagle 400 forged crank EXTERNAL balance with eagle connecting rods with a 5.7 length attached to silver lite 12cc D-dish pistons oversize to .030 stoke of 3.480 and rod of 5.7...paid about 1000 for it let it go for 600 obo
World Sportsman 2 heads, 200 cc intake runners, 64cc chambers with 2.02/1.60 valves, 1.250 valves springs, push rod guide plates, screw in rock arm studs, fully assembled ready to go all you need are push rods and rocker arms thats it, there cast iron and are a little dirty but a good set of heads...paid 700 from a friend of mine let em go for 550 plus shipping obo
Painless engine wiring harness for the 85-89 camaro/firebird, extra long version...paid about 375 brand new let it go for 200 plus shipping obo
Thanks for looking
Thanks for looking
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
Re: Some Performance Goodies
ill give u a bump good luck
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
How many teeth on the fly wheel, 168 OR 153 ?
Engine: Carb 355
Axle/Gears: 4.11
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: Carb 355
Axle/Gears: 4.11
its for a tpi, i looked up the wrong part number. to back up my mistake and to prove tht this is meant for tpi heres a link to my other post that i sold my mini ram setup on that i used the harness on https://www.thirdgen.org/forums/engi...ttle-body.html sorry for the mishap
Car: 82 Z28
Transmission: T400
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Crank should be 3.75 stroke for a 400. Was this a 377 kit?
I'm building a shopping list for mine now and may be able to use the crank and rods.
Thx,
Jp
Engine: Carb 355
Axle/Gears: 4.11
Sorry for the delay guys, my grandmother end up in hospital and ive been going for the last past couple of days heres some pics
Keith Black Silverlite pistons
Engine: Carb 355
Axle/Gears: 4.11
Painless wiring harness...
Has everything, relays, moduels, mat sensor, cold start injector connector, starter wires, fuel pump main power tie in wire, fan relay ground wire, knock sensor, etc etc
Engine: Carb 355
Axle/Gears: 4.11
I have the jegs mini high torque tht can bolt with both 168 and 153 flywheels
Pac J
May 17, 2020 10:44 AM
