parting out 1989 iroc-z 5.7tpi
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Re: parting out 1989 iroc-z 5.7tpi
How much for the pbr rear brake set-up with the parking brake cables shipped to Canada.
lmk
Cash Ready
lmk
Cash Ready
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
how much for just the calipers and brackets. 125 shipped is the going rate.
lmk
lmk
no. thanks anyway. i'd end up with $80 after shipping and a rear thats probably not worth anything. the only good thing thats a plus on the rear is the pbr brakes. disk posi's are a dime a dozen.
Good luck? 4th gen pbr's can be had for under 75 bucks and they are basically the same.
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Do you have a power antenna? If so must be the original GM one, not the universal replacement and must work of course.
Car: 89 Formula 350
Engine: 355
Axle/Gears: 3.27:1
Payment sent. Please let me know when it ships. thanks
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
Do you have exhaust manifolds and y-pipe shipped to 32333?
the pipe can be cut right before the cat
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
how much for the wonder bar shiped 2 Lancaster CA 93535
complete car being parted. all original 5.7 car. pbr disk rearend $250. tpi setup with harness and computer $300. motor raps. power mirrors $50 pair. foglamps with rusted rings $40 shipped (us). tilt column w/key $70 shipped. wonder bar $45 shipped. maf sensor $60 shipped. nice gray seats. iroc rims--tires junk. much more. pics tomorrow.
TC
501-240-9767
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
How much for the rear shipped to Malvern, Arkansas 72104? What gear is it? How much for the wheels shipped?
Car: 91 Z28 CONV
Engine: 468 BBC/500+HP
Transmission: TURBO 400
Axle/Gears: 9"FORD W/373 POSI
do you still have the mass airflow sensor if so how much with shipping to 11801. thanks john you can email me directly at fajdad@aol.com
LT1Formula
20
Nov 14, 2015 12:02 AM
