Cleaning the garage and found brand new rear calipers from 84 firebird.
I have the lines and parking brake stuff as well
Also, I have the front calipers from same vehicle.
Front and rear backing plates have been glass beaded I also have spindles.
If interested contact me
Jeff
Jeff
how much for the parking brake lines? put an 83 t/a rear end on my camaro and need the cable to link the parking brake so that when i pull the handle something happens. lol
I willl look for them. I may have already pitched them. I did some serious cleaning last week.
These are the ones from the "Y" connector to each caliper correct?
Jeff
Jeff
actually this one never touches the axle i think you were refering to the bent metal tubes that run to the caliper. I switched from drum brakes and theres a long line with a connector on the end taht had a big rubber protector on it that plugged into the drum that operated only the e-brake. its the one that tightens when you pull the handle. I don't know how it hooks up on disks because I bought the rear-end separate from the car and it was unhooked already...
PM'd
