[IL] 82-92 alum driveshaft, '92 spindles, spare tire, wheel adapters
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
so I have a few things to get rid of now as I am getting the car re-done. Below is all the stuff I want to get rid of. Smaller things I am willing to ship, larger stuff I would rather just have someone come get it locally, but PM me and we can see what I can work out
'92 z28 wheels. These are about an 8.5 out of 10. Small spots where moisture got behind the clearcoat. A little sanding and clear re-spray and these are mint. Zero curb rash, I had them professionally re-done back in '01 and they have been parked in a garage since '04. Tires are not worth anything as they are very old, consider them a freebie if your tight on cash - $375 SOLD
spare tire and hardware. It won't work with my new brakes - $25
z28 air box with stainless ducts from hawks - $100 SOLD
(2) unused still in the plastic k&n z28 filters - $45 SOLD
lakewood non-adj lower control arms with urethane bushings. They were installed and driven 1000 miles in '04, been parked ever since - $45 SOLD
lakewood non-adj panhard rod with urethane bushings. Same story as LCA's - $40 SOLD
C5 Z06 28# injectors. Installed in '07 on new motor. Dyno tuned and that's all the use they ever got - $100 SOLD
tpi egr valve. Test fired on a motor and that's it - $10
front spindles. Nice shape for brake modification - $75 for pair
3rd gen aluminum drive shaft - $100 SOLD
brand new front sway bar rubber end links from PST - $10
Brand new 4th gen rear wheel adapters from hawks with lugs.......unused as well - $75 SOLD
Car: 1982 Z28 Camaro
Engine: 383 Stroker
Transmission: TH350
Re: alum driveshaft, lakewood susp parts, wheels, 28# inj
Interested in the wheel adapters.. if they're 2 inch, pm paypal info please.
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
Re: alum driveshaft, lakewood susp parts &more
i'll take the driveshaft and lca's!
Engine: 4++,350 & 305 CIs
LCA's are pending, but I do still have the drive shaft. Actually just hit it with de-greaser and a red scotch brite pad and it cleaned up really nice!
Re: alum driveshaft, Z28 wheels, C5 Z06 28# inj, spindles
Bump, some stuff sold
updated, still a few things left
Car: 1990 IROC
Axle/Gears: 10 Bolt 3.23
Re: 82-92 alum driveshaft, '92 spindles, spare tire, wheel adapters
are the wheel spacers still available?
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
Sorry I spaced on updating this thread. Been mainly working off PM's I'll be updating it soon with a bunch of other barely used/new stuff I decided not to use in my build. I'll have:
P600B Procharger and base plate
UMI trans cross member for use with relocation torque arm
Magnaflow 2.5" double inlet/outlet SS muffler
AutoMeter mechanical vacuum/boost gauge
Snow Performance methanol injection controller (or possibly whole stage 2 kit if I can't integrate into Holley HP setup)
and maybe a few other things. Just need to pick stuff back up from shop and figure out a few more things before I let it go
1992rs/ss
05-19-2020 07:02 PM
