[NH] Comp Cams 08-304-8 Roller Cam
Old Nov 15, 2009 | 01:21 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
This is a brand new, never installed Comp Cams Roller Cam. Specs are as follows:
Brand COMP Cams
Manufacturer's Part Number 08-304-8
Part Type Camshafts
Product Line COMP Cams Computer-Controlled Camshafts
Summit Racing Part Number CCA-08-304-8
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 1,400-5,400
Intake Duration at 050 inch Lift 210
Exhaust Duration at 050 inch Lift 220
Duration at 050 inch Lift 210 int./220 exh.
Advertised Intake Duration 266
Advertised Exhaust Duration 276
Advertised Duration 266 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.510 in.
Valve Lift with Factory Rocker Arm Ratio 0.500 int./0.510 exh. lift
Lobe Separation (degrees) 114
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Computer-Controlled Compatible Yes
Grind Number CS 266H-R14
Quantity Sold individually.
Notes Requires use of custom programmer or computer chip.
New this cam sells for $265
My price is $200 shipped in the lower 48.
I can take PayPal or credit card over the phone.
Contact me with interest.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
