Brake swap guys: C5 front Brembo blank rotors
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
C5 front Brembo blank rotors.
First pair: They are practically new. I put them on, and slightly warped them while bedding my pads. Have them turned and they will be good as new. Literally only have about 20 miles on them. Light surface rust from sitting in my garage. $35+shipping obo.
Another pair of front C5 Brembo blanks. Freshly turned and should be ready to go. $35+shipping obo.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Car: 91 Z28
Transmission: t-56
Re: Brake swap guys: C5 front Brembo blank rotors
Not sure. The set that is already turned look like they took off a decent amount of material. The set that isn't turned, probably isn't much. They didn't shake that bad when I had them on. When I bedded the pads, I got a little too much heat in the rotors and it glazed the pads. So I just put new of both on.
About $35.
About $35.
sjorgens
Oct 1, 2015 07:54 PM
