[MD] Hypertech TPI inginition coil
Old Jan 9, 2010 | 11:20 AM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
Used about 3K miles $40+ shipping
The Hypertech Power Coil is 40% more powerful than stock, supplying 53,000 volts of energy, which is 15,000 volts more than stock. The Power Coil is capable of firing a street engine right up to the "red Line" without skipping a beat.
For years, racers have been increasing their spark plug gaps in order to increase performance. However, a higher voltage is required to force the electrons to jump the larger gap between the plugs.
The larger, more powerful spark produced by a Power Coil and a larger spark plug gap will usually show an increase of about 5 horsepower on the dyno, and will also fire the air/fuel mixture more efficiently at part throttle cruising speeds.
Hypertech Coil for dual connector GM Applications, Fits in factory brackets (thru 95)
Old Jan 10, 2010 | 10:51 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: Hypertech TPI inginition coil
gunna need a picture of it...
Old Jan 10, 2010 | 12:07 PM
1986z28's Avatar
I can get one. it looks like this:
http://www.summitracing.com/parts/HYP-4055
Fast355
Dec 2, 2016 06:33 PM
stalkier
Dec 6, 2015 11:25 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 5, 2015 11:02 PM
