Multi-Point Fuel Injection, Stealth Ram, Speed Density, 1,000 cfm MPFI
Old Apr 4, 2010 | 09:00 PM
rdicarlo's Avatar
Car: 1986 Camaro
Engine: 72 350 4Bolt Main from a C20
Transmission: 700R4 B&M Shift Kit tci converter
Axle/Gears: Borg Warner 9 bolt 3:42
Hi, I was going use this setup on my 80 Corvette, but I decided that the vette could use the cash more. I traded a street bike that I had for the system. My friend put 1000 miles on it, before he sold the car and saved it for another project that never happened.
Brand: Holley
Manufacturer's Part Number: 91403201
EGR: No
Injection Style: Multi-port
Metering Style: Speed density
Intake Manifold Included: Yes
Intake Section Included: Complete
Intake Material: Aluminum
Intake Finish: Satin
Engine Block Style: Stock/OEM standard deck
Fuel Rails Included: Yes
Throttle Body Included: Yes
Throttle Body Mounting Flange: GM TPI
Venturi Quantity: 2
Venturi Diameter (mm): 58.00mm
Airflow Rate (cfm): 1,000 cfm
Throttle Body Material: Billet aluminum
Throttle Body Finish: Satin
Injectors Included: Yes
Injector Size (lbs/hr): 24 lbs./hr.
Calibration Module Included: No
ECM Included: Yes
Wiring Harness Included: Yes
Oxygen Sensor Included: Yes
Fuel Pump Included: Yes
Fuel Pressure Regulator Included: Yes
Distributor Included: No
MAP Sensor Included: Yes
IAT Sensor Included: Yes
TPS Sensor Included: Yes
IAC Motor Included: Yes
Laptop computer required for calibration.
Sells for $3149.95 at Summit Racing http://www.summitracing.com/parts/HLY-91403201
I want $2250 for the kit. It comes with all the car parts on the table in the pictures...
Let me know if you have anything of equal value to trade. I'll consider trades and/or cash/paypal. I live in Massachusetts. Buyer pays for shipping.
Thanks,
Rob
Old Apr 9, 2010 | 07:37 AM
rdicarlo's Avatar
Car: 1986 Camaro
Re: Multi-Point Fuel Injection, Stealth Ram, Speed Density, 1,000 cfm MPFI
Any trades out there? I could use performance heads and intake manifold...
Old Apr 9, 2010 | 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Not much call for complete setup on here because most 3rd Gen owners already have a ECM and harness ; they only need the intake.
Might have better luck on a Hot Rod Forum
Old Apr 9, 2010 | 11:31 PM
rdicarlo's Avatar
Car: 1986 Camaro
thanks for the tip,
Rob
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
