LT1 Assembly $500 or part out
Old Apr 13, 2010 | 12:41 AM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
LT1 Engine assembly that had been running in my 88' Monte Carlo until the oil pressure dropped and Crankshaft siezed. Engine has everything needed to do the swap except Valve train(timing chain, lifters, valve springs, camshaft, pushrods, rocker arms, valves).
For $500 You will recieve everything in the pictures shown here:
http://img704.imageshack.us/gal.php?g=lt1topendkit2.jpg
LT1 PCM(ready to fire up an engine), auto trans engine harness(used but in working condition), Block, crankshaft, Rods, Pistons, oil pan, 1 piece rear main seal, timing cover, oil pan, oil pump, pick up and shaft, oil pump drive gears, oil pan gasket spreader kit, crankshaft hub, flywheel, lifter retainers and spider plate, camshaft retainer(broken and will need repair or replacement), water pump drive sleeve, Corvette Accessory Bracket, Corvette bracket tensioner pulley, Corvette A/C compressor(bought from checker autoparts but never used. Has been open to atmosphere for about 5 years so may not work anymore. If it is toast, then the core alone is still worth over $100), Steam Pipe, Street and Performance Steam Pipe Fitting(goes in the upper radiator hose and connects to the Steam Pipe. You really shoudl use this component if you use a regular radiator with the LT1's reverse flow cooling. Otherwise head warpage may occur.), LT1 port matched Intake Manifold and Heads. One of the Heads was overported and opened to the lifter galley. Will need repair or replacement. I drove the car like this for over 10,000 miles with no noticable problems though. LT1 fuel rail w/ stock injectors. LT1 factory Throttlebody with SS logo painted on the top plate. LT1 Centerbolt Valve Covers, Large style starter, works with LT1 Flyweheel.
I tried to name it all off, but I might have forgotten something.
Or I Will sell the following individually:
PCM $75
Automatic trans Engine Wiring Harness $150
Short block assembly $150
LT1 Heads(1 is damaged, but repairable) $75
LT1 gasket matched Intake $100
The Corvette Acessory bracket has been sold.
ASP underdrive crankshaft pulley/balancer p/n 945800 $100
GM performance parts Carb Timing adapter $40
LT1 Fuel Rail with stock injectors $75
Corvette A/C compressor w/clutch $50 (Never used but has been open to the atmosphere)
Thanks, Rodney.
Old Apr 22, 2010 | 02:15 AM
Daddy-o85's Avatar
Car: 92 Camaro RS
Engine: 3.1
Transmission: 5 Spd
Re: LT1 Assembly $500 or part out
Interested in the intake manifold. Can you send pics? NOFX__2@hotmail.com
Old May 4, 2010 | 06:11 PM
dare20's Avatar
What year is the motor?
Old May 4, 2010 | 07:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Part # on PCM and has it had the VATS programmed out of it or any tuning mods?
Old Jul 30, 2010 | 02:44 PM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
Did you have any sort of covering across the inlet to the compressor? Will the compressor still turn over (not the clutch)?
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
