parting out 1989 gta--many parts
Old May 27, 2010 | 03:21 AM
89irocz355's Avatar
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
parting whole car. 5.7tpi--auto--pbr disk 3.27 posi
Old May 27, 2010 | 10:44 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: parting out 1989 gta--many parts
How much for the fuel lines from fuel rail to lines on the frame? (both steel and rubber lines)
Old May 28, 2010 | 01:28 AM
generalchase's Avatar
Car: 1991 pontiac firebird
Engine: 1991 3.1l LHO
Transmission: Th700r4
how much for v8, harness, computer?
Old May 28, 2010 | 12:33 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
need the air tube from the cat converter if you have it
Old May 28, 2010 | 01:19 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Axle/Gears: Too lazy to check!!
I need a fuel sending unit.
Old May 28, 2010 | 07:58 PM
89irocz355's Avatar
$35 shipped
89irocz355's Avatar
$35 shipped
Old May 28, 2010 | 07:59 PM
89irocz355's Avatar
$600 picked up
Old May 28, 2010 | 08:00 PM
89irocz355's Avatar
$40 shipped in the 48 u.s.
Old May 29, 2010 | 08:57 PM
ZOOCREWRACING's Avatar
Car: 91 GTA
Engine: 5.7 ,ALUM CORVETE HEADS
Transmission: 700R
LOOKING FOR A 700R ..???$$$$
Old May 29, 2010 | 09:08 PM
knight123's Avatar
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
how much for the rear, master & portioning valve if i pickup? How many miles on it?
Also rear hatch and spoiler if I pickup?
thanks
Old May 30, 2010 | 01:33 AM
89irocz355's Avatar
thanks
$250 for the rear setup. 108,000 miles. 3.27. great shape.
rear spoiler is beat.
Old May 31, 2010 | 04:22 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
would you happen to have the speed sensor for 700r4 ?
Old Jun 22, 2010 | 08:25 PM
lakin454's Avatar
Car: 88 Firebird Formula
Transmission: WC T5
Axle/Gears: 9 Bolt 3.45
Looking for the battery cables if they are on the drivers side? Shipping to 03608 or can pick up.
Old Jun 22, 2010 | 11:29 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Does it have the door panels with molded armrests? If so what color and how much shipped to 30439 Metter Ga?
Old Jun 23, 2010 | 06:24 PM
johnrstuch's Avatar
Car: 89 Trans am GTA
Axle/Gears: not sure
pigtail air intake temp sensor
how much for the pigtail that connects in between air intake temp sensor
and the wiring harness.how much to ship to jax,FL 32219.
Old Jun 26, 2010 | 01:46 PM
SSAnimal502's Avatar
Car: 1991 Firebird Formula
Engine: 5.0
Re: pigtail air intake temp sensor
What conditions are the tail lights in? How much do you want for the tail lights and center sections?
Old Jun 26, 2010 | 05:38 PM
Dudeman1531's Avatar
Car: 91 Camaro RS
Engine: 383 FiTech
Transmission: T-56 BW
Axle/Gears: 3:42 10 Bolt
How much for the rear brake setup? Shipped to 99208
Old Jun 27, 2010 | 06:37 AM
89irocz355's Avatar
here are some pics. theres a chip out of middle piece as shown in pic. can't see it when the hatch is closed. $70 shipped
Attached Thumbnails parting out 1989 gta--many parts-100_3465.jpg   parting out 1989 gta--many parts-100_3467.jpg
Old Jun 27, 2010 | 06:39 AM
89irocz355's Avatar
more pics.
Attached Thumbnails parting out 1989 gta--many parts-100_3466.jpg   parting out 1989 gta--many parts-100_3468.jpg
Old Jun 27, 2010 | 06:42 AM
89irocz355's Avatar
$210 shipped. rotors--backing plates--calipers--all bolts. whole brake setup.
Old Jun 27, 2010 | 06:18 PM
andrew22888's Avatar
How much for the radiator hold down. The rubber pieces to mount the radiator and all bolts to hold radiator in. shipped to 64744
Old Jul 24, 2010 | 07:35 AM
SystemX's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
I need the air filter canister with the piece of duct tubing running from the canister to the MAF sensor. Also, the distributer cover piece that bolts to the upper intake if it is aluminum. How much shipped to 48433. Thanks.
Old Jul 24, 2010 | 05:32 PM
Trans89Am's Avatar
Want a title? Post!
Car: 1989 Trans Am
How much for motor without the tp
LT1Formula
20
Nov 14, 2015 12:02 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
kyleb24
Aug 15, 2015 08:24 AM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Aug 6, 2015 08:57 AM
