[CA] Nitrous Wet Kit (with MSD ignition)
Hey guys, i bought this from a member on LS1tech, but i have decided to go a different route, So this will help fund my turbo LT1 300zx project. Here are the specs.
Price is 450 Shipped to your door, continental US only. I know i am not active on this site, but if you search my screen-name, you will see i am active on many other forums and have good feedback (albeit i ship a little slow sometimes... work is a bitch) I use the same screen-name across all forums.
There were two bottles run through it, so it is in very good shape. This is a VERY complete setup with alot of extras:
NOS wet system, 100hp pills currently installed
-NOS 10lb blue anodized bottle
-NOS bottle blanket
-bottle mount brackets mounted on custom carpeted mount (mounts in T-top area of F-bodies)
-NOS bottle heater
-4an feed line
-fuel/nitrous solenoids w/mounting brackets
-fuel rail schrader mount for fuel feed
-NOS single nozzle
-100hp pills
-MSD RPM window switch w/mounting bracket
-NOS purge solenoid/line
-MSD 6A ignition box w/GM harness for plug/play operation (96-97 style)
-solenoids/WOT switch neatly wired into MSD box/wire looms
-WOT switch
I would like 450 SHIPPED!. Will also trade for a large turbo. Either the BW S475 or MP T76. I MIGHT consider the T70...
-NOS bottle blanket
-NOS bottle heater
-4an feed line
-NOS single nozzle
-100hp pills
-WOT switch
Engine: 360
Axle/Gears: Richmond 4.10 with Moser axles
Re: Nitrous Wet Kit (with MSD ignition)
i am interested, but cash flow is a little tight with my current build. If we can get in the threes somewhere, I would probably be a buyer.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
