406 Torque Monster
Old Jun 30, 2010 | 12:58 PM
sstpres's Avatar
406 Torque Monster
Have a new motor but sold the car. Need to sell the motor.
400 +.030 GM Block. Filled to the bottom of the Water pump holes. Decked and plate honed. Machined and Assembled by local performance machine shop.
Sportman II Heads Pocket Ported with new SS valves 2.02/1.6 and springs.
10.3CR. New rotating assembly including SCAT 9000 internally balanced crank, SCAT 6" capscrew rods, Mahle FT pistons and dampner. Deep sump pan(New). Camshaft is a Willhoite grind(OKC,OK) Hyd.roller. 281/287 Adv. and 230/236 @ .050 with a 110LSA(Basically a XE282HR copy). New 1.6Rockers so the lift is .544/.555".
Great S/S motor. Needs very little in the way of converter stall and gear. It will run power brakes. And this motor will take a 150shot of juice with no problems. It only has run time on a start stand to check for leaks, valve adjustments and problems. Have video of it running if you're interested.
STICK THIS BABY IN YOuR CAR AND SCALD THE TIRES. $3600.
Old Jun 30, 2010 | 02:43 PM
sstpres's Avatar
Re: 406 Torque Monster
Oh! Forgot to add this has a Crosswind manifold as well.
Old Jul 31, 2010 | 02:26 PM
sstpres's Avatar
This motor is still F/S. Will throw in a good used Powershot plate and solenoids. I will palletize this for shipment or you can pick it up.
Old Aug 1, 2010 | 11:00 AM
likeyoumeanit's Avatar
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
location?
Old Aug 1, 2010 | 12:14 PM
sstpres's Avatar
I'm located in southern Oklahoma. The motor is at the machinist in Lone Grove, OK.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
