[KS] Comp Hi-Tech Pushrods 7.300
Old Aug 22, 2010 | 11:44 AM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Set of used (700 miles) pushrods. Only removed due to head change requiring a different length pushrod. The only wear if from the usual guideplate rub. These are the thick ones that will not bend. Summit price $134 new. Mine will be $75 shipped in the lower 48.
Part number is 7949-16
Attached Thumbnails Comp Hi-Tech Pushrods 7.300-101_2689.jpg   Comp Hi-Tech Pushrods 7.300-101_2690.jpg
Old Aug 22, 2010 | 01:48 PM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
Re: Comp Hi-Tech Pushrods 7.300
will you do 60 shipped, Im buying blindly. Not sure if I need 7.26 or 7.30 length for my retro fit
Old Aug 23, 2010 | 09:02 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
$70 shipped???
Old Aug 23, 2010 | 09:41 PM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
65 ? what was your setup. I want to buy but wanna buy right size for my retro fit using edelbrock rpm alum heads comp cam and retro rollers
Old Aug 24, 2010 | 08:40 AM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
I was using AFR 195's then stepped up to the AFR 210's. I had to go a little longer on my new ones to get my rockers to clear the springs better.
I can do $65
Old Aug 24, 2010 | 07:37 PM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
the reason I ask about setup cus Comp Cams kit has 7.26 rods in there retro kit .My only worry cus I do want them jus dont wanna by wrong one .did you use a sizing tool for rod length
Old Aug 24, 2010 | 09:36 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Yes i have the measuring pushrod. I also did have a thicker head gasket that could be why mine were longer a tad bit
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
