Ram Jet 350 Engine w/ EFI Connection LS1 PCM 24x Conversion
Old Sep 7, 2010 | 10:02 PM
S10Wildside's Avatar
$5,500.00 or best offer. Willing to ship if you are willing to cover shipping costs. Engine is located in Erie, PA.
Compare to GM 12499120 Ram Jet 350 assembly for $5,800.00 from Summit Racing... where GM bundles the undesirable MEFI 4 ECU. Notice that the engine in this listing uses the LS1 PCM and is tunable by anyone who can tune an LS1 car.[/b]
About this engine...
- 1989 L98 short block with 10k original miles (very clean engine)
- New GM Perforamance Vortec heads (same as Ram Jet 350 crate)
- New GM Perforamance Ram Jet 350 Camshaft
- New GM Performance 1.6 roller rocker arms (same as Ram Jet 350 crate)
- New Ram Jet 350 Intake Manifold, Throttle Body, Fuel Rails and Regulator
- New Billet Aluminum Timing Cover
- 24# Fuel Injectors
- Flexplate Included
- Starter Included
- Front Accessories and Water Pump NOT included
- Reddish color oxidation visible on intake manifold (difficult to see in pics)
- Test stand NOT included
- Electric fan NOT included
- Headers NOT included
- Fuel Pump NOT included
EFI Connection 24x Conversion
- LS1 PCM control
- Coil per Cylinder Ignition with coil bracket assemblies
- Wire harness has provision for 4L60E transmission and T56 Reverse Lockout
- PCM includes a calibration that has been tuned on both dyno and street
- Can be tuned with EFILive, HP Tuners, or LS1Edit.
- More at http://www.eficonnection.com
Videos of this engine running on test stand
- http://www.eficonnection.com/forsale...mJet350_01.wmv
- http://www.eficonnection.com/forsale...mJet350_02.wmv
Please call EFI Connection, LLC at 814-566-0946 if you are interested. You may also email sales@eficonnection.com.
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
