Lots of stuff!!!!
Old Oct 26, 2010 | 10:22 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Lots of stuff!!!!
Ok I need to clean out my garage so here it is. sorry for so much to read but I like to be precise as I can so I don't have to answer a lot of questions and I know most is intior related but there is some that isnt.
I have a good condition dash pad from my 91 rs it is still glossy has one corner where i had to repair the vinyl (cant notice it though unless you look real close) there are like 2 small cracks in the vinyl where the vents for the speakers are. and a few of the mounting holes in the defrost vent area are sunk in from where previous owner over tightened the bolts and there is a small spot in the center of the dash were a radar detector was glued ( just a little residue left from removal). Over all once dash is installed you cant really notice any of the defects. Im looking for 50.00 obo plus shipping.
Stock antenna 5.00 plus shipping
I have 2 rear sail panels ( both are the boards alone not covered in material) one is plastic one is the particle board that was commonly used both would be good to recover in vinyl, fabric etc...Make offer, plus shipping.
A set of acrylic t-tops some stress and heat fractures that are common with the acrylic ones. Still lock and seal good and dont look bad. 60.00 obo plus shipping.
I have a spare 110mph gauge cluster, (basically good for parts or if you want to use it to make your own holder for auto-meter gauges) the speedo is not intact and the tachometer chip is missing and the clear plastic lens is missing, but it still has most of the needles, the bezel is in great shape and like I said is great for parts and if you want to try to make your own custom gauge cluster without buying an expensive spare. I would like 15.00 plus shipping.
I also have a brand new 3.73 ring and pinion set for 7.5 10-bolt, I paid 160 plus shipping but will take 120.00 plus shipping.
PM me or post im on alot so ill get back to you, I can send pics or post just let me know
Nick McCardle
Sep 10, 2015 08:36 PM
NiG
Sep 7, 2015 11:25 PM
Jetmeck
Sep 4, 2015 12:29 AM
