[NC] 86 trans am 9 bolt posi
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
raer end from my 86 trans am its a 9bolt borg warner with disc brakes and 3.27 gears pick up only
300.00
300.00
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: 86 trans am 9 bolt posi
Do a search on here too but they are marginally stronger than a 10 bolt. The things its got going for it is bolt in axles rather than c-clips on the 10 bolt and all 9 bolts are 28 spline. I have one in my camaro and its a pretty decent rearend if it was taken care of and doesnt have too many miles. Even if it has a lot of miles (like mine probably does) you can pull apart the posi and shim it tight again.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
