[TN] WC T-5 Trans and more, 92 RS Part out
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I have a ton of parts laying around from a 92 RS I stripped a few months back and they all need to go. All parts are local pickup only in the Chattanooga, TN area. I can meet you at a reasonable distance as well, just ask. Also I won't be home for another two weeks as I'm currently oversea's. However if your interested then shoot me a PM and I can contact you as soon as I get stateside, will be on the 20th of November.
1.) 92 WC T-5 V8 trans... comes with bellhousing, crossmember and shifter. Shifts great, drove the car from Knoxville to Nashville then back to Chattanooga before tearing it apart. Trans felt tight, no synco issues that I could tell. I am keeping the clutch pedal assembly, shifter plate and hydraulics for my IROC. Although I may have a spare 5 speed shifter plate, I'll check and see.
$500.00
2.) TBI 305 complete with Serpentine drive and all accessories. Engine runs but smokes and is very weak. In need of a rebuild. Mileage unknown.
$150.00
3.) Driver and Passenger doors with windows. Power door locks and power windows. Drivers door has a small rust spot on the bottom, just appears to be surface rust and looks like an easy fix.
$100.00 each or $150.00 for both
4.) TBI fuel lines, from tank to engine compartment. I believe these are the same as the TPI lines. Has the same fittings anyway.
$50.00
5.) Pin on cowl hood... free to whoever buys the engine or trans.
6.) 92 RS dash, complete. All gages worked great, dash in excellent condition except for dash pad. It's cracked in a few places.
$100.00
7.) 92 RS ground effects... I'll throw in a good drivers side fender, front bumper cover and rear bumper cover as well. Good condition...
$150.00
8.) Complete set of grey seats... drivers side has a couple tears, needs recovering. Non power...
$150.00 for the set
I have various small parts as well, just ask what you need and I'll see if I have it. If someone wants all of this I'll throw in everything for $800.00... including Misc.. interior plastics.
My email is utfan01ss@gmail.com as well...
Thanks,
Mike
$500.00
$150.00
$50.00
$100.00
$150.00
$150.00 for the set
Thanks,
Mike
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 5, 2015 11:57 PM
