[NV] Holley Stealth Ram Intake + 58MM TB
Old Nov 6, 2011 | 11:35 AM
taman86's Avatar
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
I got a HSR that has about 10K miles on it.
There is no corrosion on it.
Also comes with Aftermarket 58MM Wide Throttle Body.
Will fit either pre or post 86 Heads.
Will work for 305 or 350 engines.
This Setup came out of a car with a brief electrical fire, there is a little soot on the parts, and you will need to buy a new Holley Fuel Pressure Regulator, plus some fuel line, to go from the stock line to the HSR.
This set-up is alot easier to assembly or take apart than the stock TPI set-up.
$250 for The HSR
$150 for the 58MM TB
Attached Thumbnails Holley Stealth Ram Intake + 58MM TB-sspx0385.jpg   Holley Stealth Ram Intake + 58MM TB-image09012011061619.jpg   Holley Stealth Ram Intake + 58MM TB-image09012011061546.jpg
Old Nov 6, 2011 | 12:18 PM
taman86's Avatar
Re: Holley Stealth Ram Intake + 58MM TB
More Pics
Attached Thumbnails Holley Stealth Ram Intake + 58MM TB-image09012011061652.jpg   Holley Stealth Ram Intake + 58MM TB-sspx0384.jpg   Holley Stealth Ram Intake + 58MM TB-image09012011061558.jpg
Old Nov 9, 2011 | 12:16 PM
amargari's Avatar
Car: 73 Camaro LT/RS
Engine: 327
Transmission: Supert T-10
PM Sent
Old Nov 12, 2011 | 12:25 PM
taman86's Avatar
Sold the Intake set-up, But still have the 58MM Aftermarket TB.
$140 Shipped to anywhere in 48 states.
It is a BBK Power-Plus
There are 3 small screws missing of the six that attach the bottom piece. It is still secured by the 3 remaining screws.
Attached Thumbnails Holley Stealth Ram Intake + 58MM TB-image11132011140609.jpg   Holley Stealth Ram Intake + 58MM TB-image11132011140631.jpg   Holley Stealth Ram Intake + 58MM TB-image11132011140651.jpg
Old Nov 16, 2011 | 09:02 PM
taman86's Avatar
58MM TB is now sold, THX
Hotrodboba400
Dec 10, 2019 07:07 PM
Stangski09
Nov 14, 2015 01:27 PM
86CamaroDan
Sep 29, 2015 10:08 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
