700R4 parts
Old Nov 6, 2011 | 05:25 PM
Drac0nic's Avatar
700R4 parts
OK, This is what I have.
-1989 700R4, no third gear has the following parts:
-2200RPM stall S10 converter
-9C1 shift valve (4th does not down shift)
-'vette servo
-Transgo HD kit
-Low milage (less than 35K) separator plate
-.5 boost valve
-Drain plug kit
-Case will likely need some helicoils it does leak
-I also have a 1991 9C1 Caprice core transmission. It has a 'vette servo, but is in pieces as well.
-Rebuild kit, with Beast Sun shell, .5 boost valve, Corvette servo, Raybestos Z-pak. Still in box.
-Stock 305 TPI V8 torque converter, I believe this is in good condition it was pulled for a race car.
-Stock TPI TV cable, probably about 200 miles on it. I have the box as well I believe.
With the core transmissions, converters and the parts in the one I want $350 for the lot. If you want something specific please make an offer and I will consider it before breaking up the lot.
Old Nov 7, 2011 | 12:38 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: 700R4 parts
Location?
Old Nov 8, 2011 | 10:54 AM
Drac0nic's Avatar
Re: 700R4 parts
Apologies, I live in Joliet IL.
Old Nov 12, 2011 | 11:33 AM
Drac0nic's Avatar
Re: 700R4 parts
TTT
Old Nov 14, 2011 | 11:15 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
Re: 700R4 parts
the tv cable would u do fifteen shipped to 28012 also send pics harmony92@live.com
Old Nov 16, 2011 | 04:28 AM
Werewolf SS's Avatar
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
Re: 700R4 parts
70 shipped on the stall converter?
Shipped to Florida.
Old Nov 21, 2011 | 03:46 PM
wesilva's Avatar
Transmission: 200R4
Re: 700R4 parts
Shipping a core would break the bank. What do you want for the following:
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
fonzie85
Aug 13, 2015 11:50 AM
1nastygta
Aug 8, 2015 07:38 PM
