[OH] 10 Bolt Rear End
Old Dec 12, 2011 | 07:10 PM
ChevyTech's Avatar
10 Bolt Rear End
10 Bolt rear end for sale. It has a stock housing and drum brakes from a 1992 Camaro, Moser 28 spline axles, Moser structural aluminum cover with bearing cap preload studs, a Zexel torsen limited slip from a 2001 firebird, and 3.73 ratio ring and pinion.
The rear end was recently rebuilt with all new bearings along with installing the 3.73 gear. It was driven less than 500 miles and had a slight gear whine. The 3.42 ring and pinion that came out to put the 3.73 set in were quiet and I will include them in the sale along with the original 3.08 ratio still on the open diff.
I am also including a set of 4th gen disk rear brakes that can be adapted to work with this rear end (Comes with rotors, parking brake assembly, calipers, pads, lines, and park brake cable).
The only reason I am selling this is because I replaced it with a 9 inch. Asking $500.
Attached Thumbnails 10 Bolt Rear End-p1010007.jpg   10 Bolt Rear End-p1010003.jpg   10 Bolt Rear End-p1010012.jpg
Old Dec 12, 2011 | 07:13 PM
ChevyTech's Avatar
Re: 10 Bolt Rear End
More pics of the 3.42 ring and pinion, and some of the brake parts.
Attached Thumbnails 10 Bolt Rear End-p1010015.jpg   10 Bolt Rear End-p1010017.jpg   10 Bolt Rear End-p1010008.jpg
Old Dec 14, 2011 | 04:55 PM
ChevyTech's Avatar
ttt
Old Dec 18, 2011 | 11:23 AM
ChevyTech's Avatar
bump
Old Jan 11, 2012 | 08:57 AM
ohiosteve's Avatar
PM sent
Old Jan 11, 2012 | 11:28 PM
ohiosteve's Avatar
Sold... to me. Outstanding folks to deal with... wish they live next door. Very knowledgeable.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
