[IL] 496 Big Block Chevy. Brand new.
Old Dec 25, 2011 | 10:42 PM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
Motor specs
427 punched out to a 496 stroker.
Internally balanced
Bore 4.310
Stroke 4.250
New Scat Steel Crank
New Manley H Beam Rods
New SRP Pistons
New JE Rings
New Clevite bearings
New Chromoly Push Rods
New Springs
New Valves
New retainers
New Locks
New Keepers
New Valve seals
New Comp Cams Hydraulic roller lifters
New Comp cams Hydraulic roller cam Lift 612 Duration 314 on a Lobe of 110.
Chevy Oval port heads. 2.06 Intake 1.72 Exhaust
Canted degree angle.
Competition valve job.
New Timing chain
New Oil Pump
New Freeze Plugs
New Edelbrock RPM Air gap Dual Plane Intake
850 Demon carb
New March Pullies
New flex fan
New Edelbrock Mechanical Fuel Pump
New MSDdistributor
New water pump
New Moroso Plug wires
Air cleaner with new filter
New Alternator converted to one wire
New Thermostat housing and T stat.
New Valve cover breathers
Comes with Aluminum Overflow catch can
New High Torque stater
New Solid Motor mounts
New custom Aluminum Valve covers
The motor was thoroughly checked, hot tanked,pressure tested, bored, notched, line honed and assembled.
The motor dynoed on 518 HP and 541 TQ. Have the dyno sheet. The motor has the capabilities for 650HP with Aluminum heads naturally aspirated. It will also handle Nitrous.
The motor is together and has 540 miles on it since it was put together. Its ready from carb to oil pan ready to drop in. The only thing needed is either a flexplate or flywheel, spark plugs and your headers.
The motor cost $6,656 to build in just parts and machining. This doesnt include all the add ons of the engine. That was only the price of the long block. I have over 8 Grand in the entire setup.
I have all the reciepts for the motor build, nothing was spared. $6,000 OBO NO TRADES.
If Interested call Mike at 847-489-1982
Old Dec 25, 2011 | 11:07 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: 496 Big Block Chevy. Brand new.
Wow, beautiful job. Good luck with the sale!
Old Dec 26, 2011 | 01:25 AM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Thanks.
Old Dec 27, 2011 | 12:23 AM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
This thing is well capable of 750+ hp on pump gas. Even with Something like my 049s with 2.25 and 1.88 valves it would make 625+ hp.
To everyone This is a great start to a good motor. Put some aluminum heads on this and it's capable of 750+ hp depending on the compression.
Free bump. GLWS!!
Old Dec 27, 2011 | 01:17 AM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Thanks. Hopefully someone can use it instead of it sitting in my garage.
Old Dec 27, 2011 | 03:51 AM
85z28kid's Avatar
Car: 85 iroc-z28
If I didn't just build mine I would be interested. People who haven't experienced over 500 ftlbs of torque don't know what they're missing out on.
Old Dec 29, 2011 | 04:26 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
TTT...
Old Dec 31, 2011 | 03:02 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Back up.
Old Jan 2, 2012 | 09:14 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Still got it.
Old Jan 6, 2012 | 06:03 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Again.
Old Jan 9, 2012 | 04:41 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
It is OBO...
Old Jan 11, 2012 | 05:34 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Bump...
Old Jan 13, 2012 | 04:56 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
No interest?
Old Jan 15, 2012 | 08:46 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Again.....
Old Jan 19, 2012 | 04:29 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Back up.
Old Jan 22, 2012 | 12:28 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Sold.
Reddeath210
Oct 6, 2015 08:20 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 17, 2015 02:00 PM
sreZ28
Aug 14, 2015 07:48 PM
