GM Fast burn heads $1000 or best
Old Dec 27, 2011 | 11:51 AM
blue 85 roc's Avatar
Want a title? Post!
Car: 1985 iroc
Engine: 5.0
Transmission: 700r
Axle/Gears: ?
I have a set of gm fast burn heads, used for about 5,000 mis at most. Nothing wrong with them at all. Parted out entire engine. Trade for miniramIII for fast burn heads or sell for $1000 or best.
Attached Thumbnails GM Fast burn heads 00 or best-img_1646.jpg   GM Fast burn heads 00 or best-img_1645.jpg
Old Dec 29, 2011 | 08:49 PM
83 Crossfire TA's Avatar
Re: GM Fast burn heads $1000 or best
what size valves? Do you know what springs are in them/what they're good for?
Old Dec 30, 2011 | 10:23 AM
Want a title? Post!
Car: 1985 iroc
Engine: 5.0
Transmission: 700r
Axle/Gears: ?
This head can be used on any 1958-99 283-400ci small block Chevrolet V8 engine with conventional water flow design, but this head cannot be used on any LT1, LT4, or LS1 engines that are designed with reverse water flow. The all new 23° Fast Burn small block cylinder head has the highest performance potential of any 23° small block head developed by GM. The Fast Burn head combines new technologies with the best of GM motorsports and production cylinder head technologies. The design creates tremendous power on engines from 350 to over 400ci. The name "Fast Burn" refers to the head's ability to quickly and completely burn the air fuel mixture, resulting in higher cylinder pressures and more power. The shape of the combustion chamber is designed to accomplish this "Fast Burn" with flat top pistons, so flat top pistons are recommended with this cylinder head. It is not recommended that the combustion chamber be modified or reshaped, as this could decrease the efficiency of the chamber. This head is designed with a .400" deck. This new technology removes material from other portions of the head, allowing for considerably larger ports and water jacketing. The deck also provides unsurpassed clamping force for cylinder head gasket retention. The super rigid .400" deck thickness can be machined down to .340" safely for all-out performance applications and higher compression. Other ways to adjust compression ratio with the Fast Burn head include top of piston design and piston installed height. Unlike the GM Performance Parts Bow Tie heads and most aftermarket performance heads, this head requires no additional porting for maximum performance. In the past, the industry has added material to heads to allow substantial porting, which can result in poor "out-of-box" performance and additional cost. The Fast Burn head utilizes GM Performance Parts' Cast-Ported technology, which means that improvements in flow, combustion and cylinder fill were incorporated into the machining tooling, achieving maximum performance "out-of-box". While additional porting is not recommended, light sanding to remove minor casting imperfections and polishing of combustion chambers and exhaust ports is acceptable. All Fast Burn heads are CNC machined to exacting tolerances, thus eliminating the need for "blue-printing" of machined tolerances, resulting in a cost savings and unsurpassed "out-of-box" performance. This head has taller than typical rocker cover rails, providing exceptional clearance for rocker arms and valve train supports typically used in all out performance applications. The rocker rails are CNC machined for superior rocker cover gasket sealing. Front head faces are drilled and tapped for typical accessory drive bracketry. The Fast Burn head accepts both center bolt and early style four bolt flange mount valve covers. Signature etched with GM Performance Parts logo. Intake manifold mating surfaces are drilled and tapped for both Vortec and conventional raised port style manifolds. Vortec style manifolds are recommended. "D" shaped 78cc exhaust port and runners provide adequate flow for applications well in excess of 500 hp. Raised runner (.240" higher than conventional 23? head) intake ports with 210cc ports and runners provide adequate flow for applications well in excess of 500 hp. Raising the top of the intake valves provides a better "line-of-sight" through the port and onto the back side of the intake valves. The 62cc fast burn combustion chambers - the most efficient ever to be incorporated on a GM Performance Parts cylinder head - produce higher cylinder pressures by burning more of the available fuel before the piston starts its power stroke downward. By more completely using available fuel, the engine produces more power per quantity of fuel. The 2.00" hollow stem lightweight intake valves are utilized to reduce loads on valve train systems at high rpm's. The 1.55" sodium filled lightweight exhaust valves have all the same benefits of the hollow stem intake valves, and additionally they are able to perform under extremely high-temperature performance applications. This head has specially designed "deep" valve seats which can accommodate up to 2.02" intake valves / 1.600" exhaust valves. Lightweight valve spring retainers combine with the lightweight valves to help ensure long-term high rpm durability. Screw-in 3/8" rocker studs are used, and accept most available roller rocker arms. Uses all conventional "low cost" readily available 23° rocker arms and valve train supports and hardware. This head is a bolt-on 30 hp increase when used on our ZZ4 crate engine. When tested on a 383 ci small block engine with 9.5 to 1 compression ratio and .540" lift roller cam, single plane intake manifold and 750 cfm Holley carburetor, the Fast Burn heads produced 497 hp at an incredibly low 5800 rpm. Total ignition timing to be used on a Fast Burn head will vary based on a number of factors, but most configurations made the most power with 32 to 34° of total timing.
TECH SPECS: Use intake manifold P/N 12496820, P/N 12366573, 12496822, or 10051103 with the Fast Burn cylinder head. Use intake manifold gasket P/N 12529094 and eight attaching bolts P/N 12550027. Use Fel-Pro exhaust gasket P/N 1470 for these Fast Burn heads (some trimming may be required for your application). This head includes intake valves P/N 12555331, exhaust valves P/N 12551313, valve spring cap P/N 10212808, and valve springs P/N 12551483. Exhaust header with LT1/Lt4 style flanges are required. (Page) (Pic)
Old Dec 30, 2011 | 09:44 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Are you a bot? If so, go away!!
Fast355
Dec 2, 2016 06:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
hayesaw0210
Aug 23, 2015 11:15 PM
89mulletbird
Aug 12, 2015 07:08 PM
