putting my 9 inch Moser Engineering rear end up for sale
9 inch housing set up for a 3rd gen width
weld on relocation brackets
31 spline axles
Detroit True Trac Differential
Have either a stock case or a Strange S nodular case (+150)
also have 2 sets of gears. 3.70's or 3.25's but i would like to keep the 3.25's
also comes with drum brakes. cannot remember exactly which ones they were but were the biggest ones you could get at the time.
also has 3 x 1/2 inch Moser wheel studs
rear end has 2200 miles on it. im just getting rid of it since im going to a spool and 35 spline axles and want to put Aerospace rear brakes on it as well. and also one with a back brace on it for safety purposes.
looking to get 1800obo or 1950 with s case
pictures
31 spline axles
pictures
does factor torque arm and sway bar bolt right up or i guess is it a direct bolt up replacement for 3rd gens
Quote:
Originally Posted by 89irocconvt
does factor torque arm and sway bar bolt right up or i guess is it a direct bolt up replacement for 3rd gens yep everything bolts right in. i believe you will just need to get new U-bolts for the 3 inch axle tubes instead of the factory size axles tubes. its an easy swap over.
it also comes with the adapter for the torque arm to bolt right up that comes from moser as well
pm sent
Speedfreak391
close
This is sold! To me!
Quote:
sweet congrats to you and Sean!Originally Posted by Speedfreak391
This is sold! To me! Yes grats on the buy.
Lucky!! Lol gotta change what your axle/gears combo is now its a 9" instead of 9bolt
This is sold! To me! true story.. i should have it out by next weekend for you.. new one should be ready to go under the following week..
