parting out 1987 gta trans am--5.7tpi
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Car: '92 Angrybird
Engine: 305 TBI the "Leaky Bastard"
Transmission: 700R4 with B&M shifter
Axle/Gears: 3.21 Posi off of '93 Camaro(RIP)
Re: parting out 1987 gta trans am--5.7tpi
Quick ratio steering box? how much?
Dual fan setup sold?
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Interested in the prop valve and the dual fans if they are not sold.
How about the metal heater tubes that are on the passenger side frame rail betweent he blend valve and the heater core... have those by any chance?
#8 on the picture above... looking for some with minimal rust... mine look like swiss cheese and i dont like how close the rubber hoses get to the exhaust manifold...
idk why the image wont show... try the link #8 in the diagram
http://parts.nalleygmc.com/showAssem...hString=heater
Car: 1988 PONTIAC GTA TRANS AM
Engine: 305 TUNED PORT INJECTED
Transmission: T5 BORG WARNER 5 SPEED
Axle/Gears: 3.45 Positrac
i need the intake boot that comes after the maf sensor and goes to the filter rubber piece
Car: 85' T-Top Trans-Am
Engine: 305cid TPI
Transmission: 4 speed auto
Hello, I am not sure what you have left, but I am looking for a few parts. I am looking for a maf, passenger side tail light and if its a t-top i also need a headliner ???.
I live in Nampa ID. 83687 If you have the MAF which one is it ?. Thanks !!!
Engine: 305cid TPI
I almost forgot something. I have 16" gta snowflake wheels with the center caps. But I am looking for the emblems that go on the end of the center caps. If you can help, lemme know and thanks.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
How much for the ribbed rubber intake tube that mounts infront of the throttlebody?
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
sent on the valve thanks
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Do you still have the MAF sensor?
Car: 87 camaro/ 78 gmc serria classic
Engine: 2.8 soon to be 350/ 350
Transmission: 700r4/ turbo 350
Axle/Gears: have no clue.
Looking for shocks and struts and front sway bar, how much shipped to Kenai Alaska, 99611?
Car: '57 Chevy 3200 pickup big window
Engine: L98 350...zz4 longblock
Transmission: corvette 4+3
Axle/Gears: 3.38:1
I am looking for that 90 degree ribbed maf duct that goes from the throttle body to the maf If you still have it, What's your pay pal?
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
How much for the complete engine wiring harness, hvac harness and charging harness. With the relays. I want all the wires under the hood except the head light and fan stuff.
Digital dash, 700R4????
Also if it is cut let me know. I really want one with no splices or cuts in it.
Car: 87 iroc
Engine: mostly stock 5.7
Transmission: jasper stage 2 700r4
Axle/Gears: stock
still got rear? is it blown" pm me with details please in dire need of one! ill drive up and pick it up
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Are the GTA taillights available? How much shipped to 03865?
I need the digital odometer if it has the digital dash. How much shipped to 50027? Thanks!`And just out of curiosity I have the 1987 GTA but it has rear drum brakes. I have read about you talking about the proportioning valve, Were is that at? Is there one on a rear drum break car?
Engine: L98 TPI 5.7L 350
Transmission: 700R4 Automatic
Hey will you sell the fuel rail w fpr? Does it have 9th inj?
If so how much to ship to 90280? Thanks.
Car: 1990 TA
Engine: 350 in the works
Transmission: th700r
Axle/Gears: 10 bolt Eaton Posi 373
91 Post an nobody even asked about the tranny. Do you have it ? Is it stock ? Ever rebuilt. Works well ? I'm interested. Patrick.
Car: 1989 GTA Trans Am
Engine: 5.7 Tpi Soon to be LT1
Axle/Gears: ?
I'm also trying to get a fuel rail or just the fpr housing. Shipped to 92592
Car: '92 Camaro RS | '11 E92 335i
Engine: 305 TBI V8
Axle/Gears: Stock
have kick down cable? and need fuel lines that run from fuel rail to rubber hoses, if you have any of it how much shipped to 19711?
Car: 1986 Pontiac Trans Am
Engine: LG4 305/V8
hey interested in the front and rear sway bars if you still have them sipped to 07501
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Interested in the MAF sensor and entire digital cluster. Are these still available?
Car: gunmetal 88 gta 98 yamaha vmax
Engine: l98
Axle/Gears: bw 9 bolt 327
if you have a set of gta or formula wheels id be interested pm please
Looking for WS6 steering box pls email oddjack@sbcglobal.net thanks
