[NJ] SBC 383 Stroker
Old Jan 31, 2012 | 09:05 AM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
SBC 383 Stroker
Motor in the car is a SBC 350 4 bolt main 1 piece rear main seal which 3.75 forged Scat Crank and 6 inch Forged H-Beam Rods with KB Forged Pistons bored out .30. Motor has a total of 56 miles on it. Has brand new main bearings, connecting rod bearings, and all new gaskets winter of 2010. Its Rotating assembly is Scat Internal balanced. All Forged with H-Beam Rods. Keith Black Forged pistons. Rods are 6in. Trick flow Super 23 195 Alu. Heads,Trick Flow® Roller Rocker Arms, Trick Flow® Chromemoly Pushrods,Trick Flow Hydraulic Flat Tappet Track Max Camshafts (.510/.518 lift ),Trick Flow® Billet Steel Timing Sets, Edelbrock Victor Jr Intake, Holley 750Dp Carb with choke milled off just rebuilt, Moroso 7qt storker oil pan. MSD Distributor. Also comes with proform Electric water pump,summit mini starter.
Needs new oil pan gasket.
Asking 5500 obo
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
