Miniram
Old Mar 8, 2012 | 05:29 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Miniram
ported to 1206,-8 edelbrock fuel rails,edelbrock 58mm tb(includes tps and iac),reworked water neck
$600.00
Old Mar 9, 2012 | 02:46 PM
blue 85 roc's Avatar
Want a title? Post!
Car: 1985 iroc
Engine: 5.0
Transmission: 700r
Axle/Gears: ?
Re: Miniram
Please email me pics of the porting, I am very interested and will take it if everythings up to snuff.
email to duanehawley@gmail.com
Old Mar 9, 2012 | 07:24 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Re: Miniram
Will these fuel rails work with the stock L98 injectors?
Old Mar 10, 2012 | 07:07 AM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
Re: Miniram
Bump, this is a great buy to whoever gets it!
Old Mar 10, 2012 | 07:28 AM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
Re: Miniram
Bandit is the MR complete and ready to run as pictured? If not what else is needed?
thanks
Old Mar 10, 2012 | 08:14 AM
Re: Miniram
I'm not selling this, just giving the ad a bump.... although in the description he wrote said that the throttle body and rails were included...if they definitely are then this is a great deal....miniram alone is around 800-900 I beleive. Also to the other comment, I don't see why stock injectors wouldn't work, but it does look like the fuel rails need a crossover line.
http://tpis.com/parts/view/34
Old Mar 10, 2012 | 08:29 AM
rongreen's Avatar
Re: Miniram
What is needed to make it a ready to run system?
Old Mar 10, 2012 | 08:35 AM
Re: Miniram
Looks like it needs a throttle cable bracket,fuel pressure regulator, crossover line (for fuel rails, (2 ) -8 braided lines, and adapter fittings to connect braided lines to stock hard lines. Hopefully the seller will be on and can answer better than me, I'm just going off his pics.... I would check in aftermarket intake section to see what else is normally needed for this intake. I always wanted one but never got one, went single plane, but I don't see where water sensors would go.(tpi had 2 in the front of intake)
Old Mar 10, 2012 | 12:36 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Re: Miniram
Sorry everyone, yes the rails will use any injector that is the same style as stockers. They will require a seperately mounted fuel regulator as each bank is fed in paralell,way better setup than what comes with it from TPIS. you can see each -8 line come off each rail behind the TB,over to a weldon regulator mounted by the horns.[IMG][/IMG]
Stock throttle cable is still used.
There is a sale pending,I will keep updating.
I am going single plane/4"tb with an elbow which is why i'm selling
Old Mar 10, 2012 | 12:44 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Re: Miniram
Does away with the crossover,water sensors go right next to the water neck. I needed more volume to feed 83#injectors so there is nothing left of a factory fuel system on my car
Old Mar 10, 2012 | 02:09 PM
Re: Miniram
Lol I can see, I figured as much when I saw the -8 for lines, I just dumped my stealth ram for a single plane 4bl TB setup.
Old Mar 12, 2012 | 06:48 PM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
Re: Miniram
Sold, thanks TGO
gixxer92
Apr 12, 2022 12:09 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
BWilcox
Sep 20, 2015 12:19 PM
Mutillator
Sep 17, 2015 04:38 PM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
