[NJ] 383 stroker BLOCK
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
383 stroker BLOCK
I got a deal on a new set up for my car so I figured I see if anyone was interested in my block before making the move.
The block is 4 bolt main 1 rms. I was bored .30 over and notched to my Scat Rotating assembly. Block was filled partly,mains where align bored,block was hot tank,new freeze plugs,cam bearings installed when machined. Over 900 in machining not include price of block. There is no damage to the block. only thing wrong with it is one of the main outer bolt holes is cracked.
Block has less than 100 miles on it. Block is good shape.
Motor block is currently still together will take apart when I get a buyer.
Asking 600 obo
Photos: http://www.picturetrail.com/sfx/album/view/24059149
BLOCK ONLY
Asking 600 obo
BLOCK ONLY
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: 383 stroker BLOCK
will include the following for extra 150. Bring total to 750 obo
Cam-Trick Flow® Track Max® Camshafts for Small Block Chevrolet(P/N: TFS-31401002) Hydraulic flat tappet
Lifters-Trick Flow® Hydraulic Flat Tappet Lifters (P/N: TFS-21400001) Hydraulic flat tappet
Trick Flow Valve Cover (P/N:TFS-44000)
Andrew Prakash
Sep 8, 2015 11:48 AM
