[MI] Gm Performance Hydraulic Roller Camshaft
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Like the title says i have a Gm performance hydraulic roller camshaft. I purchsed a crate motor in september and only ran that engine for 2 months and then replaced the cam with another one. The car did run 12.97's with this cam with vortec heads. It's the cam that usually comes with the ht383 crate motors. you can read all about it here...
http://www.summitracing.com/parts/NAL-14097395/
I'd like to get $100 shipped, as im sure theres barely any miles on it and i have it out and is in great condition. If you want pictures of it just let me know!
Engine: sbc 383
Transmission: Th400
Re: Gm Performance Hydraulic Roller Camshaft
Sure, what would you like to know? The specs are in the link and like i said i was only driving with it for a couple months not even. Hydraulic Roller Tappet, Advertised Duration 288/308, Lift .431/.451. duration @ .050 196/206.
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
Like the title says i have a Gm performance hydraulic roller camshaft. I purchsed a crate motor in september and only ran that engine for 2 months and then replaced the cam with another one. The car did run 12.97's with this cam with vortec heads. It's the cam that usually comes with the ht383 crate motors. you can read all about it here, the specs are in the link and like i said i was only driving with it for a couple months not even. Hydraulic Roller Tappet, Advertised Duration 288/308, Lift .431/.451. duration @ .050 196/206.
I'd like to get $120 + shipping, as im sure theres barely any miles on it and i have it out and is in great condition. If you want pictures of it just let me know!
You have a PM Sir.
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
What kind of power woukd this cal put out on a 350 Sbc with vortec heads.?
Engine: sbc 383
Transmission: Th400
I had it in my vortec head 350, and like i said the best time i made with it was a 12.97 at 105 mph. It was a very good cam, and it ran that with only a 2200 stall and th350 trans, with a 3.73 rearend.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
