Just pulled the entire engine out of my buddy's '86 Z28 yesterday because I need the long block for one of my many projects that I have going, but I will be using a Holley Stealth Ram with this motor so I am selling the original TPI system that came with it. This TPI system comes complete with everything; lower intake, upper plenum, throttle body, runners, distributor, fuel rail, injectors, EGR, each and every bolt, everything is there and ran flawless on the engine. Was told the injectors on the fuel rail are 24-lb's, but I haven't confirmed this yet, and have no need to because I run much larger injectors for my turbo anyway and I can't use them. I'm also throwing in an additional set of 19-lb Delphi injectors too. This is the earlier TPI system, and is ideal for you small block chevy guys that are running non centerbolt heads and want to convert to fuel injection. Or, for you later small block chevy guys running centerbolt heads that want to convert from TBI to TPI, you would just need to elongate the middle bolts on the lower intake. Asking $200.00 for the setup. Gonna put this up on a few other boards, and then eventually ebay. If you need more pictures just say the word. Thanks fella's...
- Rob
- Rob
Just sold it all for $100.00, enjoy it Mike...
- Rob
- Rob
