[CO] Reprogramed tpi maf memcal
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Tis is for a good used memcal for user REDBEARD71 . This memcal is currently a broadcast code ACXW from a 87 f-body tpi 305, 700r4. This memcal will be reprogramed To ARAP 1989 corvette. This programing does not use the ninth injector. Vats delete, air pump function delete, no egr or egr code 32, knock sensor be delete code 43. cooling fans on at 200F and off at 185F $80 shipped
Engine: Lb9
Transmission: M20
Re: Reprogramed tpi maf memcal
I will get it reprogramed for you and send you a tracking number when the paypal payment clears. It states The e-check is expected to go through on Aug 1, 2012.
Engine: Lb9
Transmission: M20
Funds still have not posted I will keep you informed
Engine: Lb9
Transmission: M20
funds posted, your usps tracking is 9405509699939042277807
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
