Firestone airbags ( inside rear springs)
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Blue, rated 1,000 pounds per pair, only used once, for 15 minutes, with great success. I paid $85 delivered, make fair offer. If I can get 2 commitments, I'll split the pair for use as drag bags, in which case you just pit one in the right rear coil, then add 5-35 psi.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Firestone airbags ( inside rear springs)
They're gone, but there was virtually NO lift un-loaded. Loaded, here's the difference they made;
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Sorry for the confusion. Let me put it another way: Even with the airbags inflated, the car still squatted under the trailer, but not as much as with no air in the airbags. Here's a pic of the ride height with no bags and no trailer:
sailtexas186548
Aug 26, 2015 03:32 PM
