383 stuff. afr heads. full roller motor.
Old Aug 29, 2012 | 01:53 AM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Transmission: th-350
Motor was fresh build with all new parts. Scat crank, rods and speed pro 860cp pistons. 1 piece rear main block full roller motor. Afr 195cnc heads. Motor broke a piston and scratched #6 bore. Needs new pistons and to be bored to .040. Rest of stuff in perfect shape with no affects from broke piston. Block went to machine shop and they can verify all it needs is pistons and to be bored. Spent 5,600 on build and have all reciepts. Willing to part if enough interest. Otherwise carb to pan 2100. Pm for more specs and pictures.
Old Aug 29, 2012 | 05:57 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: 383 stuff. afr heads. full roller motor.
What AFR heads?
Old Aug 29, 2012 | 09:49 AM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
They are 195cnc race ports. They are the version just before the new eliminators. Less then 1k on them since freshen up. Guy I got them from got them brand new and only ran the car about 20 minutes before it lost a camshaft. I had them checked out and freshened up with new valve springs for my roller cam.
Old Aug 29, 2012 | 10:10 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am interested, but I would like to know more. Why did a piston break? Did the crank need reground? Is it a steel scat crank? what was the compression ratio? What are the combustion chambers and intake port size? And maybe most important, what is the location? Sending PM too.
Old Aug 29, 2012 | 04:26 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
heres a few pictures when motor was first assembled.
Old Aug 29, 2012 | 04:27 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Old Sep 1, 2012 | 07:26 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Heads with rockers sold. Pushrods and everything underneath still for sale. make offers
Old Sep 4, 2012 | 07:41 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
What intake and Dizzy does this motor have?
Old Sep 5, 2012 | 11:01 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
IntKe is a weind accelerator and dizzy was a mallory but not for sale anymore. Rest of motor still for sale. Good parts here people. Got block back from machine shop and I'm confident with a new piston it would be fine. Very very very light scratch in #6 cylinder that you can't even feel. $800 for shortblock....
Old Oct 4, 2012 | 09:44 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
do you still have this eng? are you willing to part w/ the cam?
if so do you know the spec on it.?
Old Oct 4, 2012 | 10:22 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Yes cam is still here. Custom hydro roller from Herbert. 233/242 at .050..540/.555 lift with 1.5 rocker. 109 lsa.
Old Oct 4, 2012 | 10:39 PM
88 Z-ROC's Avatar
are you willing to part w/ it?
Old Oct 4, 2012 | 10:40 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Yes. It's a billet core BTW. 145 plus shipping.
Old Oct 4, 2012 | 11:24 PM
88 Z-ROC's Avatar
pm sent
Old Oct 5, 2012 | 07:52 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
what is the part # on heads and what model year are they?
Frank
Old Oct 6, 2012 | 02:05 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Most of motor is gone. Only thing that's left is the cam and pushrods and intake. Heads are sold.
Old Oct 7, 2012 | 05:13 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
do you have a fuel pressure regulator?
Old Oct 7, 2012 | 08:11 AM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Yes, mallory 4309 return style. It's what everyone runs in these cars with a Carb. Only 500 miles on it and I bought it new. $65 shipped
Old Oct 10, 2012 | 04:12 PM
Engine: L31 350
Would you do $50 shipped on the FPR?
Old Oct 10, 2012 | 05:22 PM
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Yeah ill do $50 shipped anywhere in USA.
Old Oct 17, 2012 | 11:04 AM
shwinny's Avatar
If you stl have the heads I'll buy today. Shoot me a pm.
Old Oct 17, 2012 | 11:22 AM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
Read buddy.
midge54
Dec 27, 2019 04:14 PM
gixxer92
Sep 1, 2015 04:32 PM
IrocZ'85
Aug 17, 2015 06:24 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
