[MI] SBC Lunati Solid Roller + Springs.
Old Nov 1, 2012 | 12:21 PM
TB2's Avatar
TB2
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
SBC Lunati VooDoo Solid Roller retrofit Cam. part#60131. Used one season. "same as new" Condition. Exellent cam for mid to low compression small block chevy motors.
Solid roller, rough idle. Good cam for high performance street or mild strip applications. Needs 2500-2800 RPM stall speed converter, 9.5:1 or better compression, aftermarket exhaust system and 3.73 rear gear ratio.
•Advertised Duration (Int/Exh): 267/273
•Duration @ .050 (Int/Exh): 237/243
•Gross Valve Lift (Int/Exh): .566/.578
•LSA/ICL: 110/106
http://www.lunatipower.com/Product.aspx?id=1992
SBC #954 COMP Cams Valve Springs
$200 for all of it.
tbrobotics@hotmail.com
gixxer92
May 18, 2017 11:20 AM
sammy52401
Nov 11, 2015 07:20 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
skinny z
Oct 5, 2015 06:23 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
