[KS] Ford 9inch rear disc brake setup
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
Rear Disc Brakes Setup, For a ford 9inch big bearing, from Moser. 11" rotors single piston calipers and brackets. rotors drilled for 5x4.75. 600 miles on setup. $250 shipped.
Re: Ford 9inch rear disc brake setup
Can you measure back from the wheel mount surface to the back of the caliper (toward the center of the car. I need to know if they will clear my LCA on a narrower than stock axle.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
