[MD] Rebuilt 083 5.7 TPI heads. Ready to run.
Old Feb 12, 2013 | 02:55 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
$195 + shipping Pair of recently rebuilt 14101083 casting # 64cc 1.94/1.5 iron heads (1987-1992 5.7 camaro/firebird TPI heads). The valve guides were bored .015" oversize and new oversize stem valves fitted, and full valve job done, about 10k miles ago. The valve stem premium viton seals are still nice and fresh. Ready to run. The valve springs are stock and should be replaced if you plan on running a cam larger than ~ .450" lift. These are a great head to replace your high mileage worn out 083 heads or replace your TBI heads.
Each 083 head, in a box, weighs 54 lbs and measures 23x9x7, for shipping reference.
Old Mar 20, 2013 | 10:47 AM
Car: 2000 BMW M5
Re: Rebuilt 083 5.7 TPI heads. Ready to run.
bump, updated ad to reflect the one remaining set of 083 heads I have left
Old May 21, 2013 | 12:17 PM
Marc Maro's Avatar
Car: 1991 Camaro Z28
Engine: 5.7 TPI, Dyno Don Headers
Axle/Gears: Eaton Posi - 3.42
Are these still available? Shipping to 94605.
Old May 21, 2013 | 12:37 PM
Car: 2000 BMW M5
Those heads just sold but I have one more pair of 083 heads w/ similar very low mileage, under 10k miles, that also have a fresh 3 angle valve job, all new valves and resized guides, and additionally have new aftermarket valve springs set up for a mild hyd roller cam, and have been pocket ported. All the valve installed heights were shimmed to get consistent, correct spring pressures @ 1.75" installed height, and I used 16 regular non-rotator retainers. These springs are good for .550" lift but I would verify guide to retainer clearance if you are planning on running a cam at or above .485"+ lift. I am pulling them off a .450/.460" roller cammed .040 over TPI setup that I was running in a truck. I would sell these 083 heads at the same price $195+ shipping
Shipping is $104 for both heads to your zip
This is what they are coming off (1988 K1500 that has a frame that is succumbing to rust), if you want the heads I will pull them immediately and send you pictures before shipping them.
Here are the heads from when this engine was going together a few years ago
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
86IROC112
Aug 21, 2015 07:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
