[MD] Holley Stealth Ram w/ fuel rails, throttle body, Kirban billet AFPR, 24 lb injectors.
Old Mar 5, 2013 | 02:56 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
-----SOLD----- ------SOLD----- -----SOLD------
Old Mar 6, 2013 | 03:57 PM
Demonic13's Avatar
Car: 1991 Chevrolet Camaro 25th Anniv.
Engine: 5.7L 350 TPI
Re: Holley Stealth Ram w/ fuel rails, throttle body, Kirban billet AFPR, 24 lb inject
I am interested. I will give you the full price you ask. I see its for NON vortec I just have a stock L98 350 will this bolt on? If so i will send you a PM and pay right away. Thank you.
Old Mar 6, 2013 | 04:29 PM
Car: 2000 BMW M5
Yes I have run this on L98 heads in the past, it will fit. The only thing to note when installing it, is that the 4 center intake bolt holes on iron L98 heads (083s) are drilled at 70 degrees, not 90 degrees like the four center bolt holes on early gen 1 heads. The stealth ram has elongated center holes so it will fit either year range heads, just make sure you use four grade 8 3/8-16x1" flange head bolts in at least on the center 4 holes because they will hit the intake at a slight angle and cheap bolts in that location will bend.
Old Mar 6, 2013 | 04:38 PM
Demonic13's Avatar
Not sure if it makes a difference. i have the cast iron heads not the aluminum. As for the location of the bolts, when you say: "4 center L98 bolt holes are drilled at 70 degrees, not 90 degrees like the rest. The stealth ram has elongated center holes so it will fit,"
That is japanese to me. I will not be able to bolt it up properly? Please confirm before I buy. Where can I get these Grade 8 bolts? Thanks.
Old Mar 6, 2013 | 04:39 PM
Car: 2000 BMW M5
call me, I sent you my phone # in a private message, I will explain
Old Mar 11, 2013 | 09:18 AM
Car: 2000 BMW M5
-SOLD-
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
09ave
Sep 7, 2015 06:03 PM
