good used 6al
Old May 17, 2013 | 07:54 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
good used 6al
worked good when pulled to replace with the digital 6 setup new been repaired and always worked as it should. 80 bucks shipped to you. If you know how to test off the car I wll gladly do it as been sitting in the garage on the shelf for around 2 years but should be just fine car was parked longer and fired right up prior to changing it.
Old May 20, 2013 | 07:35 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Re: good used 6al
you firm
Old May 20, 2013 | 09:10 PM
lt1z350's Avatar
Re: good used 6al
For now but if doesn't sell quick I will come down but on eBay and with 22 watchers it is looking good it will sell at the end of tomorrow after that if not would be flexible but for now first to pay gets it
Old May 21, 2013 | 08:48 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Re: good used 6al
Did it sell?
Old May 23, 2013 | 06:08 AM
lt1z350's Avatar
Re: good used 6al
Yea went over 100bucks too. I have a Holley box if interested in that one will do cheaper it was never installed on anything been sitting since new.
Old May 23, 2013 | 04:34 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: good used 6al
Which holley box is it?
Old May 23, 2013 | 08:27 PM
lt1z350's Avatar
Re: good used 6al
Holley annhialator part # 800-100 I even have the book still. I got it for a bronco project and it wouldn't work right with the ford ignition system it had so never ran it and always had some sort of msd on my car so it just sat. I believe it has an internal rev limiter u set with dials behind a panel on it. Black and about the same size as a 6al.
Old Jun 10, 2013 | 05:42 AM
rabblerouser's Avatar
Re: good used 6al
do you still have the holley box? if so how much shipped to 06042?
Old Jun 10, 2013 | 06:32 AM
lt1z350's Avatar
Re: good used 6al
Yea I will do 90 shipped it was 180 new and personally from the bench test I have done this throws a hotter spark than either msd I have tested with a msd coil. Plus dials no chips for revlimit. It is new just was installed so no run time on it at all. I have the manual too.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
