[CO] Tpi Reprograming Service Tpi Maf
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Change 87 tune to 1989 tune for 305 automatic transmission
Solder in dip socket and include a sst27sf512 flash eeprom
Disable vats
Verify fan switch selection and set correctly
Disable egr code 32 and egr and air pump function
Fans on 200f and off 185f
Max speed limiter to 255mph
Set tcc lockup to 45 mph.
$75 shipped with tracking
This ad is for a tgo member
Disable vats
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Re: Tpi Reprograming Service Tpi Maf
This tune is for my car. Brian has been VERY helpful in the process so far. I will update once everything is done.
Engine: LB9 | LS1
Everything is done. Brian has been SUPER helpful and has been timely. He is knowledgeable, and an important asset to this forum. I will certainly continue my business with him in the future!
Engine: Lb9
Transmission: M20
Thank you again for your buisness and support
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
