isaackvasager
close
- Join DateMay 2012
- LocationMinnesota
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1982 Camaro - Z28/Indy Pace Car
- EngineCarburated 350 (originally 5.0 CFI)
- TransmissionTH200c Piece o' Crap
- Axle/Gears2.73
- Liked:0 Times in 0 Posts
Hi all,
I am restoring a 1982 Pace Car Edition that came with the 305 c.i. Crossfire Injection Setup. I have decided to upgrade to a 350 carb. in my rebuild and therefore have no need for the current engine.
It was a running engine, although needed minor work. I have the motor completely taken apart because was originally planning on rebuilding the stock motor, but decided if I'm going to do all this work I may as well get a 350.
Anyone interested in any of the parts?
Block, heads, rods, camshaft, intake manifold, throttle bodies, injectors, exhaust manifold, wiring harness..etc. Everything is original stock, so if your looking to rebuild a crossfire injection engine to stock I might be able to help you out.
I'm probably upgrading the tranny also, so if anyone wants the TH200c let me know!
Let me know what you might want and we can discuss price...I'm not looking to make huge money, just want to get it out of my garage!
I can take pics of anything you may want.
I am interested in the ECM and the plastic flywheel cover for the trans.
isaackvasager
close
- Join DateMay 2012
- LocationMinnesota
- Axle/Gears2.73
Quote:
I can do the flywheel cover for sure. Don't need much for that, $5 + shipping sound ok? I have another member that has previously contacted me about the ECM and I'm waiting to hear back from him. If he doesn't get the ECM its yours! ($15 or so?) PM me if you would like to make a purchase...thanks!Originally Posted by 82tarecaro
I am interested in the ECM and the plastic flywheel cover for the trans. Supreme Member
Sent you a pm.
I'm restoring a pace car as well, but am keeping the CFI.
What condition is the wiring harness in? Are any of the connectors broken or damaged? Do you plan to retain the hood flap assembly and if not, what condition is it in (any rust around the rubber seal)?
I'm interested in CFI set up....?
How much....?
How much....?
