[Sold] MiniRam 1205
Old Aug 23, 2013 | 09:43 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
MiniRam 1205
I have a 1205 miniram with fuel rails for sale, comes with everything you see in the pic's. The previous owner modified the coolant ports and added lines to the back of the intake to equal out the flow. Also there was a slight port matching done at the top of the ports, about 1/8" deep but still matches the 1205 gasket fine. Anyways I would like to get [SOLD] shipped anywhere in north America.
Old Aug 23, 2013 | 10:07 AM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: MiniRam 1205
Would this work with a 1206 gasket and 220cc ports?Thanks
Old Aug 23, 2013 | 01:32 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: MiniRam 1205
With a little bit of gasket matching I don't see why not.
Old Aug 25, 2013 | 12:36 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: MiniRam 1205
ANOTHER great deal on a ports too big, (for me ), MR. Rats! GLWS
Old Aug 29, 2013 | 11:16 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: MiniRam 1205
Bump
Old Sep 1, 2013 | 04:24 PM
karl's-92'-z28's Avatar
Car: Too many cars
Re: MiniRam 1205
Non vortec heads?
Old Sep 1, 2013 | 09:47 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Re: MiniRam 1205
Curious why the extra coolant line work? I hav the same setup withou the cooolant....any reason for it?
Old Sep 3, 2013 | 11:10 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Re: MiniRam 1205
PM sent!
Old Sep 3, 2013 | 11:57 AM
Tony89GTA's Avatar
Car: 89 GTA
Re: MiniRam 1205
Originally Posted by karl's-92'-z28
Non vortec heads?
Yes non vortec
The previous owner Mike Davis put them in, it's to supply the back coolant ports and to equal out the flow. I actually like the idea a lot and it was nicely done with stainless hardware.
Old Sep 4, 2013 | 10:36 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Re: MiniRam 1205
How much porting I need to do to get them to work on stock 113/zz4 heads
Old Sep 5, 2013 | 12:12 AM
Tony89GTA's Avatar
Car: 89 GTA
Re: MiniRam 1205
You would have to port your heads to this intake, you might be better off with a 1204 sized miniram.
Old Sep 5, 2013 | 01:18 AM
3rdgearslammer's Avatar
Re: MiniRam 1205
still for grabs?
Old Sep 5, 2013 | 11:48 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: MiniRam 1205
Yup
Old Sep 6, 2013 | 04:26 PM
Re: MiniRam 1205
I've got the 1205 on the old. Zz3 heads which I'm sure are same or smaller than zz4. I was able to get a good match with just a little Drexel work on the heads ... I bet it would work on zz4. Fwiw.
Re: MiniRam 1205
Dremel...sorry
Old Sep 9, 2013 | 01:34 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: MiniRam 1205
Good old dremel It's a slow process but it does do the job for sure. If you are willing to port match the heads then there is no reason why this wouldn't work for you.
Old Sep 9, 2013 | 01:44 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: MiniRam 1205
Ok my last price drop and I'm including the shipping too. New these things go for over $1300 shipped!!
Old Sep 9, 2013 | 01:48 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: MiniRam 1205
Mike Davis is a legend around here!
Bump for a good deal. I'm tempted to pick it up myself. I'm tired of shifting at 6000!
Old Sep 13, 2013 | 03:36 PM
slrvette's Avatar
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
Re: MiniRam 1205
Im very interested.
PM sent!
gixxer92
Apr 12, 2022 12:09 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
BWilcox
Sep 20, 2015 12:19 PM
Mutillator
Sep 17, 2015 04:38 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
