[IL] Nearly Complete T5 Set Up from 92 RS V8 Car
Old Sep 8, 2013 | 09:11 PM
hotrodder355's Avatar
Car: 1991 RS Convertible
Engine: 377 w/Holley Commander 950 EFI
Axle/Gears: 2.73:1 with Auburn Posi
I have a near complete t-5 set up. Located in East Peoria Illinois. I have the tranny, shifter, bell housing, pedals, new clutch master cylinder, used slave cylinder and used line from the master to the slave but I'm missing the reservoir and hose from the reservoir to the master cylinder, cross member, inspection cover, flywheel, and the used clutch. I bought the tranny but never used it. I bought the tranny a few years ago but just sold the car and I could never find the time to put it in. The previous owner said everything was good but I never verified. The flywheel needs resurfaced and I would replace the clutch. I do know it came from a 92 RS with a 305 V8. PM me if interested. Asking price is $850 but may entertain offers. I would prefer pickup since I don't have time to build a crate and I imaging shipping would be expensive.
Attached Thumbnails Nearly Complete T5 Set Up from 92 RS V8 Car-t5-1.jpg   Nearly Complete T5 Set Up from 92 RS V8 Car-t5-3.jpg   Nearly Complete T5 Set Up from 92 RS V8 Car-t5-7.jpg
Old Sep 8, 2013 | 09:15 PM
Re: Nearly Complete T5 Set Up from 92 RS V8 Car
More Pics
Attached Thumbnails Nearly Complete T5 Set Up from 92 RS V8 Car-t5-2.jpg   Nearly Complete T5 Set Up from 92 RS V8 Car-t5-4.jpg   Nearly Complete T5 Set Up from 92 RS V8 Car-t5-5.jpg
Old Sep 8, 2013 | 09:16 PM
Even more pics
Attached Thumbnails Nearly Complete T5 Set Up from 92 RS V8 Car-t5-6.jpg   Nearly Complete T5 Set Up from 92 RS V8 Car-manual-pedals.jpg
Old Sep 10, 2013 | 09:13 PM
Bump
Old Sep 11, 2013 | 11:34 PM
harhar12's Avatar
Want a title? Post!
Car: 1992 RS
Axle/Gears: 3.73 Auburn
Originally Posted by hotrodder355
Bump
interested in selling the pedals? ship to a u.s. address
Old Sep 12, 2013 | 05:41 AM
I would like the keep it all together as a complete conversion but if someone wants just the transmission and other pieces and does not need the pedals your first in line for them.
Old Sep 14, 2013 | 09:49 PM
Saturday night bump
Old Sep 20, 2013 | 09:49 PM
TTT
Old Sep 24, 2013 | 09:33 PM
Nobody is interested? Offers?
Old Sep 30, 2013 | 07:45 AM
TTT
Old Oct 7, 2013 | 05:48 AM
bump
Old Oct 7, 2013 | 07:56 PM
D&S 85 IROC's Avatar
Car: 85 IROCZ
Engine: 350 TPI with a fast EZ efi
Transmission: t-5 conversion
Axle/Gears: 3;42
is the trans a world class t5
Old Oct 7, 2013 | 11:00 PM
Yes I would say its world class. Came from a 92 v8 car.
Old Oct 15, 2013 | 09:28 PM
Go Cardinals!
Old Oct 21, 2013 | 01:22 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Still available for pick up?
I'm interested if you still have this set up.
Leon
Old Oct 21, 2013 | 09:16 PM
blakerose's Avatar
A fellow Iowa bro appears. I am also interested if a deal isn't worked out.
Old Oct 22, 2013 | 11:20 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Look at the front bearing and see if it says "timken." If so, WC and if not, not NWC.
Old Oct 23, 2013 | 04:15 PM
I'm not sure what you consider the front bearing so I attached 2 pictures of the front of the tranny. Each picture is showing 1 side of the transmission. The input shaft kinda divides it in half for photo purposes.
One side has: "W.G.DLV." then after a bit of space it has "13-52"
The other side has: "027-912" then after a bit of space it has "K1"
Note: no quote (") marks are on the transmission. I simply used them to show what is exactly stamped on the transmission.
Attached Thumbnails Nearly Complete T5 Set Up from 92 RS V8 Car-t-5-bearing-1.jpg   Nearly Complete T5 Set Up from 92 RS V8 Car-t-5-bearing-2.jpg
Old Oct 23, 2013 | 04:48 PM
MrPackstin's Avatar
Car: 1989 GTA
That would be NWC...I am pretty sure. I don't mean to attest to the value of this setup. GLWS
Old Oct 23, 2013 | 05:00 PM
This tranny is a WC. I checked the numbers on the tag when I got it. I seen the car it was removed from. Yes it came out of a 1992 Camaro RS with a 305 V8. Since then the tag has fallen off (it was a tag with a bar code tag and the numbers do determine the WC part on the top of the trans). I kept it and have is somewhere but not sure where its at currently. Please don't make claims that you are not 100% sure on unless you have proof to back it up. Making claims on some ones thread without proof can ruin a sale. Someone with little knowledge may take your statement as absolute win actually you are incorrect. Show proof that my tranny is not a WC or don't trash my thread. Make those statements in a PM with supporting detail
Old Oct 23, 2013 | 06:13 PM
MrPackstin's Avatar
Car: 1989 GTA
Here is a link to help in determining if this a WC or NWC: http://chris66dad.tripod.com/id38.html
Here is another website with helpful information: http://www.flatheadv8.org/ernie/ernie-t5.htm
As you can see, the mere fact that it is from a V8 car does not make it a WC T5. And according to this is the only evidence you propose that it IS a WC. There are ways to conclude that it IS-why not go the extra mile for potential buyers?
I have NO IDEA if this is or not there is just not enough evidence that it is.
Old Oct 23, 2013 | 07:02 PM
Ok here are the numbers from the case in the attached pic. The 92 in the circle dictates the tranny is a 92 model year. The rest of the numbers 13-52-065-914 dictate the tranny.
Attached Thumbnails Nearly Complete T5 Set Up from 92 RS V8 Car-t-5-identification.jpg
Old Oct 23, 2013 | 07:04 PM
MrPackstin's Avatar
Car: 1989 GTA
Does that front cap have "Timken" on it?
http://www.5speeds.com/t5/index.html:
Important- Please Read before calling us:
Casting numbers on the side of the main case or extension housing CANNOT help you ID a transmission simply because the same case is used in a variety of models. Some pictures will show you ID tips. There is also a TAG ID program. The TAG id program requires the stamped number off of the tin METAL TAG bolted to the tail housing. No other numbers on the case, tail or cover are needed or will tell you anything. Our Book on transmissions has extensive detailed information and pictures on building T5 World Class Transmissions.Over this 29 year span we have seen improvments to casting designs, synchro ring designs,alloy changes, addition of reverse gear synchro's and sadly the sale of Borg Warner's T5 line to Tremec Corp.
Old Oct 23, 2013 | 07:17 PM
To be honest I don't know. If you look at the tranny its been sitting around and its not the cleanest. I went out to look and see but I cant make it out due to the scaling. Its obvious your not interested nor do I think you ever were so I'm not even sure why your continuing to harass me at this point. I'm being as open as I can possibly be. I have gone above what I think most would do by taking pics and posting right away but you continue to question my every post. At this point you have 'won" I'm sure anyone who was interested in this has decided to pass on it.
Old Oct 23, 2013 | 07:38 PM
MrPackstin's Avatar
Car: 1989 GTA
Take a wire brush to that bearing cap, it might be a WC. "Timken" will be on the outer rim of that bearing cap. Also, one suggestion (not conclusive) that it is WC is if it has red AT fluid in it. If it is a good trans it is worth near $850 as you are selling it. AGAIN GLWS.
Old Oct 23, 2013 | 07:40 PM
Take a wire brush to that bearing cap, it might be WC. Also, one suggestion (not conclusive) that it is WC is if it has red AT fluid in it. If it is a good trans it is worth near $850 as you are selling it.
Yes it has ATF in it. There is even a sticker beside the fill hole telling you to use ATF.
Old Oct 31, 2013 | 08:58 AM
crazymex83's Avatar
Car: '88 Firebird Formula 350
Engine: L98 TPI 350
Transmission: 700R-4
sent you a pm
Old Nov 7, 2013 | 04:36 PM
1RedCamaro's Avatar
still got it/? And i did my research on this when I did my last t5 swap. as i wanted to make sure I got a WC. all transmissions after 88 or 89 were WC. They all took tranny fluid and had bronze bushings or whatever. The upgraded bushings or gears or whatever it was is what made it better than a non wc-(besides the fluid) but they just started doing it to all of them in 88 or 89. They were all upgraded to bronze syncros or whatever(i dont rememeber the specific parts that were upgraded, but when I did research it didnt really make that big of a difference. So in the later year Camaros YES they are all WC. for v8s anyway. idk about the v6 ones. After all the research ive done on these transmissions a WC is a pigs hair better than a NON WC. And if your that concerned a t56 would be the way to go.
Old Nov 7, 2013 | 08:53 PM
YES.......still available!!!!
Old Nov 30, 2013 | 12:25 PM
Still Available!!!!
Old Dec 12, 2013 | 02:16 PM
TTT
Old Jan 9, 2014 | 09:53 PM
Car: 85 IROCZ
Axle/Gears: 3;42
Is this still available?
Old Jan 9, 2014 | 10:03 PM
I have someone coming to look at it/buy it on Jan 20. If that falls through I will contact you on Jan 21. Thanks for looking.
Vintageracer
Jan 10, 2020 05:33 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
RedLeader289
Sep 23, 2015 06:50 AM
aharvel50
Sep 21, 2015 07:31 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
