[MI] Selling my AJE Drop Spindles $100
Old Oct 2, 2013 | 08:12 PM
UDAMON's Avatar
Car: Mazda Protege5
2" drop I believe. Comes with spacers for using stock rotors and spacers for stock struts. Very much prefer local pick up but I could ship although it would be pretty pricy. I'd guess around $30 for shipping but if you're serious I can check.
$100
BEFORE
AFTER
Attached Thumbnails Selling my AJE Drop Spindles 0-temporary_zps5f93f5e2.jpg
Old Oct 4, 2013 | 08:40 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Re: Selling my AJE Drop Spindles $100
Could they be modified for Corvette brakes? can you some more pics of them.
Old Oct 4, 2013 | 11:19 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
How many miles on them? No cracks etc.?
Old Oct 4, 2013 | 07:42 PM
UDAMON's Avatar
Car: Mazda Protege5
I'll try to get more pictures up tonight for you. They were originally designed to accept different brackets to accept different brakes but I wasn't comfortable with the bolt on design so I welded on the bracket that accepts stock calipers. I'm not sure what's available for converting to corvette brakes but if there is anything that would normally bolt to stock spindle then they should also bolt right up to these as well.
Only had them on for less then a year minus winter. I'll get better pictures but I do not believe there is anything structurally wrong with them. I had worn out soft springs and didn't like the height so for the price I bought lowering springs and decided to just use those with my stock spindles.
Old Oct 4, 2013 | 09:53 PM
UDAMON's Avatar
Car: Mazda Protege5
Ok more pictures added. The bolted on plate is for a steering gear and you can remove that for a rack and pinion set up I believe. Also I think I had to use spacers for the ball joints (the hollowed out nuts in the first picture). I don't think the metal plate is thick enough to tighten them down all the way otherwise.
Old Nov 11, 2013 | 07:25 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
These still around?
Old Nov 19, 2013 | 09:53 AM
prossi's Avatar
ill take them if they are still available please pm me
LittleFranks
Sep 17, 2015 12:22 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
SiCkRs
Aug 8, 2015 08:12 AM
