[NM] Cylinder Heads, rotating assembly, and much more!! (CHEAP) need this stuff gone!
Old Oct 27, 2013 | 05:10 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
I have a pair of 093 heads for sale. they have around 7k miles on them since i had them machined. They have comp springs good for .500 lift.
TPI induction system that came of my 88 IROC.
Rotating assembly that has 7k miles on it. Piston are .30 over and will give around a 10.2 CR W/ 64 cc heads
I dont know what brand these headers are maybe flowtech. 1.5 ports.
I have a complete serpentine setup without the air pump.
I have a B&M shifter complete and a B&M tork master Torque converter 2000 stall just installed in my car but i never used it because i got a good deal on a t56 swap.
A stock shift select cable and a brake pedal.
I also have for Moog front coil springs used for 100 miles
2 700r4 cross members
2 700r4 torque arm bushing brackets
2 torque arms
Drive-shaft
Prices are negotiable i just need this stuff gone!
Pair of 193 Heads: 140 shipped SOLD
TPI induction system (85-88): $180 shipped SOLD
Rotating Assembly: $50 + Shipping
complete serpentine setup: 200 Shipped SOLD
Water Pump: $20 + Shipping SOLD
Alternator: $30 + Shipping SOLD
AC compressor: $35 + Shipping SOLD
Power Steering pump: $60+ Shipping SOLD
Torque Converter: $130 + Shipping SOLD
B&M shifter W/ select cable: $100 + Shipping
Shifter select cable: $15 + Shipping
Brake Pedal W/bracket: $15 + Shipping
Crank Pulley: $ 20 + Shipping SOLD
Moog coilsprings: $30 + shipping
Transmission Crossmember: $25 + shipping
Torque arm bushing bracket: $15 + shipping
Torque Arm: $40 + shipping
Driveshaft: $40 + shipping
Old Oct 27, 2013 | 05:20 PM
KMdoza7's Avatar
Engine: none
Re: Cylinder Heads, rotating assembly, and much more!! (CHEAP) need this stuff gone!
Pictures
Attached Thumbnails Cylinder Heads, rotating assembly, and much more!! (CHEAP) need this stuff gone!-20130103_011302.jpg   Cylinder Heads, rotating assembly, and much more!! (CHEAP) need this stuff gone!-20130103_012109.jpg
Old Oct 28, 2013 | 03:26 PM
83 Crossfire TA's Avatar
which moog coilsprings?
Old Oct 28, 2013 | 11:26 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Is that an aluminum driveshaft? LT1 type?
Old Oct 29, 2013 | 04:26 AM
KMdoza7's Avatar
Engine: none
They are stock replacement front springs. i forgot the part number.
KMdoza7's Avatar
Engine: none
im not sure if its aluminum, ill have to check and see
Old Oct 29, 2013 | 07:53 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Specifications on pistons brand material etc
Old Oct 29, 2013 | 08:32 PM
KMdoza7's Avatar
Engine: none
Pistons: Speedpro
Cast Aluminum
4.030 bore
Flat top
10.2:1 compression w/64CC
Ring Groves: 5/64",5/64",3/16
The rods are press fit
Old Oct 31, 2013 | 01:56 PM
KMdoza7's Avatar
Engine: none
BUMP. tell me what you need and we can work something out
Old Nov 2, 2013 | 06:40 PM
Sojer's Avatar
Sorry I need +12 pistons
Old Nov 6, 2013 | 03:09 AM
KMdoza7's Avatar
Engine: none
BUMP
Old Nov 8, 2013 | 05:30 PM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
what all work was done to the heads?
Old Nov 10, 2013 | 12:47 AM
KMdoza7's Avatar
Engine: none
No port work, they were machined 7k miles ago, everything on them was new, and they have com cam springs that will support up to a .500 lift
Old Nov 10, 2013 | 04:42 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Better pictures and info on headers and stall
Old Nov 10, 2013 | 07:37 PM
KMdoza7's Avatar
Engine: none
Headers are flowtechs I think. they have 1.5" primaries ill include a y-pipe also. I cant take a picture of them anymore because I just re-installed them on my iroc. they are VERY easy to install
Stall: B&M tork master 2000 stall, 30 spline, lockup. ill add another picture of it tomorrow.
I only installed it on my car, I never ran it. Once I installed it I took it out the next day because I got a good deal on a t-56 swap
Old Nov 10, 2013 | 07:57 PM
Engine: L31 350
do prices include shipping?
Old Nov 10, 2013 | 10:14 PM
KMdoza7's Avatar
Engine: none
I don't think I want to sell the headers anymore, I just installed them, and the dyno don headers are pretty expensive. but for the convertor ill take 175 shipped. I think shipping will be 50 so ill split the shipping cost and if its more it doesn't matter
Old Nov 10, 2013 | 10:46 PM
Engine: L31 350
Was mainly interested in the headers. Will think about the converter.
Old Nov 14, 2013 | 09:32 PM
91Camaro_RS's Avatar
willing to ship heads?
Old Nov 14, 2013 | 11:26 PM
KMdoza7's Avatar
Engine: none
Yes sir I am willing
Old Nov 15, 2013 | 12:36 AM
How much shipped to 98335?
Old Nov 15, 2013 | 11:44 AM
KMdoza7's Avatar
Engine: none
$160 shipped
Old Dec 31, 2013 | 03:56 PM
KMdoza7's Avatar
Engine: none
Bump
Old Dec 31, 2013 | 09:13 PM
Engine: 355
are these the stock heads for an l98 just rebuilt? are they still available? centerbolt style?
shippped to 95901
Old Dec 31, 2013 | 11:16 PM
KMdoza7's Avatar
Engine: none
shippped to 95901
they are not stock heads but they flow alittle less up top. They will bolt right up like stock heads though. And yes center style. ill go 115 shipped
Old Jan 2, 2014 | 12:44 PM
Engine: 355
Do you have any pictures? Can you email them to outlawfiero17@gmail.com
do you have PayPal?
Old Jan 2, 2014 | 06:06 PM
Engine: 355
What size are the chambers? I can't find any info on these heads vs. My stock heads
Old Jan 3, 2014 | 01:06 AM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
They are the iron 64cc(before milling) heads. If you have the aluminum L98 heads, yours are 58cc heads. Depending on the mill, you should be around 60-61CC chambers now.
Old Jan 4, 2014 | 10:06 PM
KMdoza7's Avatar
Engine: none
MY bad they are 193's not 093!!! sorry
Old Jan 4, 2014 | 10:08 PM
KMdoza7's Avatar
Engine: none
https://www.thirdgen.org/forums/tpi/...n-350-tpi.html
heres alittle comparison between the heads. 193 vs 083
Old Jan 4, 2014 | 10:14 PM
KMdoza7's Avatar
Engine: none
BUMP. new prices
Old Jan 5, 2014 | 12:13 AM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
would you sell that y pipe
Old Jan 5, 2014 | 01:05 AM
Engine: 355
so after reading the article. seems like these heads are fairly close to stock l98 heads. same size rocker studs? 3/8" would like to re use my rockers. you said $115 shipped thats a deal. i figure my exhaust flows better than stock but i am limited to stock intake. so up top wont make too much of a difference. figure a slight port and polish and call it a day. who's to say i cant keep my 083's and make them even better for a latter project?
Old Jan 5, 2014 | 01:21 AM
KMdoza7's Avatar
Engine: none
yes they are 3/8" studs. i have a pair on my tpi right now and i like them. I rev them to past 5k but they die alittle over 5k:/. they also provide alot of low end torque but yea $115 shipped. PM me
Old Jan 5, 2014 | 01:24 AM
KMdoza7's Avatar
Engine: none
yes ill sell the y pipe. PM me
Old Jan 9, 2014 | 12:32 AM
Brichards79's Avatar
Car: 1989 camaro rs
Engine: lo5
Axle/Gears: 373 with detroit limited slip
Still have the heads
Old Jan 9, 2014 | 01:50 AM
KMdoza7's Avatar
Engine: none
yes but they are pending sell
Old Jan 14, 2014 | 08:07 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
What do you mean by tpi induction system, what all is included
Old Jan 14, 2014 | 09:54 PM
KMdoza7's Avatar
Engine: none
the base manifold, fuel rail w/ injectors,runners, plenum,throttle body and all the sensors. the maf sensor is not included though because it doesnt work
Old Jan 14, 2014 | 09:55 PM
KMdoza7's Avatar
Engine: none
i do but shipping is alot. its $90 to ship them out
Old Jan 14, 2014 | 09:59 PM
CherryZguy's Avatar
Car: '87 Bitchin' camaro Z/28
Engine: 305 lg-4
Transmission: 700-r4, hopefully soon to be t-5
how many miles on struts? give or take... thanks
Old Jan 15, 2014 | 01:44 PM
  #42
KMdoza7's Avatar
Engine: none
i would say like 10 miles lol i switched to KYB GR2'S but they are shot now and wont come up so ig im going to replace them with these monroes now, sorry
Old Jan 18, 2014 | 10:02 AM
  #43
midge54's Avatar
Car: 86 Trans am
Engine: LG4
how much do you want for the tpi set-up shipped to 76544
Old Jan 19, 2014 | 12:08 AM
  #44
KMdoza7's Avatar
Engine: none
180 shipped sound good?
Old Jan 19, 2014 | 07:54 AM
  #45
midge54's Avatar
Car: 86 Trans am
Engine: LG4
yea sounds good
Old Jan 20, 2014 | 06:55 PM
  #46
KMdoza7's Avatar
Engine: none
Cylinder Heads sold
Old Jan 22, 2014 | 07:34 PM
  #47
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
how much for the front struts?
Old Jan 22, 2014 | 08:02 PM
  #48
KMdoza7's Avatar
Engine: none
i installed them on my car because my KYBs wouldnt come back on so theyre not for sale anymore sorry, i forgot to edit that
Old Jan 23, 2014 | 10:48 AM
  #49
KMdoza7's Avatar
Engine: none
I still have:
B&M Tork Master Converter: 2000 stall only installed never used for 170 shipped
TPI induction: 180 sales pending
Complete serp setup: 200 shipped
B&M Megashifter w/ select cable: 120 shipped
Old Jan 24, 2014 | 12:39 PM
  #50
KMdoza7's Avatar
Engine: none
TPI system is sold!
