[RI] Restored Tuned Port Injection
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
MAF / Cold Start TPI set-up for sale. Part pictured are for 85-86 SBC, but I've got an 87+ intake in similar condition as well. All parts blasted and raw aluminum except for the fuel rail, cold start, and EGR ( they were coated with grey sealer to prevent rust until the parts can get painted. ) Will need a full gasket set...... Price is $250 for all parts pictured.
This stuff was prepared for use in the 86 Z28 I rebuilt last summer,... but I ended up topping it off with an Weiand intake and Eelbrock carb instead. The only defects I could find were a couple VERY minor dings on the runners and 1 screw is busted on the TB coolant passage cover. ( also missing 1 screw ) I'm not including injectors because they are old/used and thier condition is unknown. Have many additional pics showing better detail of most parts.
All the prep work is done,..... some new gaskets and your favorite color paint makes the top of your engine look new again. If interested just post your ZIP so I can use it to get a couple shipping quotes.
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
Re: Restored Tuned Port Injection
Still got this? Would you be willing to seperate the throttle body?
Yup, I boxed this set-up and will pull it back out when needed or sold.
I do not wish to seperate the system. Sorry; but I don't have any spare TB's.....
toronto formula
Sep 10, 2015 07:31 AM
