[GA] FRSH FROM MACHINE SHOP 350 roller 1pc rms 2bolt .030 10/10 crank 2X crappy heads KIT
350 SBC short block FRESH FROM MACHINE SHOP ... MAKE OFFERS !!!
NOT assembled ... yet ..... all basically checked GOOD stock stuff ... 350-400hp MAX !
block,14093638, roller, 2 bolt main, one piece rear main seal
cut/bored/honed .030 over , new freeze plugs, cam bearings ,etc
Crankshaft .. cut .010 , .010 , 1pc seal
COMPLETE engine kit , bearings , rings , seals gasket kit ,
flat top pistons already pressed on rods
$999 outright ... not a shop ... no tax .. no cores .... no install ...
$200 for assembly ...
I've got some OK heads for another $200 .. plus assembly
1980-82 14022601 267 1.72 1.3
I just picked ALL this up from Andy at Commerce Engine Rebuilders
more parts too
aluminum intake $125 mid 80's spread bore quadrajet aluminum 14101074 tanked and CLEANED !
another $100 crank .. 10/10 .. 1969-85 3932442 305,350 cast large 2pc in 1979-82 267
rusty head#1 1986-91 14102187 305 1.84 1.5001 - EFI, swirl port
rusty head#2 1986-91 14101081 305 1.84 1.5001 - EFI, std port
more parts too
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: FRSH FROM MACHINE SHOP 350 roller 1pc rms 2bolt .030 10/10 crank 2X crappy heads
do you have a pair of the swirl ports?
UltRoadWarrior9
Apr 28, 2020 10:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
