[Sold] Moser 12-bolt rear end w/brakes
Old Dec 21, 2013 | 02:59 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Moser 12-bolt complete rear axle assembly 4th Gen width. This axle was spec'ed out for a 1995 Trans Am. It is a direct bolt in for 1982-2002 F-bodies. In a third gen ('82-92) the width will allow running 4th gen and Corvette wheels without a spacer. Third gen wheels will stick out the fenders. I had this mounted in my '87 Firebird project car. Axle has less than 10 miles on it though it has been under my project for several years. Axle was broken in per Moser direction at time of original purchase.
It does not have the ABS relucter rings mounted. I didn't need them for my '87.
Moser 12-bolt housing with F-body suspension mounts
Ford 9" style bolt in bearing ends (no c-clips!)
33-spline axles
Tratech Trutrac differential (road race posi, no clutches to wear out)
1350 pinion yoke
3.73 Gear ratio
LT1 style rear disk brakes included
Also included is a Spohn heavy duty, high speed balanced driveshaft with the larger 1350 u-joints.
I would like $1900 plus your old axle so I can keep my project a roller. Local pick up only.
Attached Thumbnails Moser 12-bolt rear end w/brakes-moser_12-bolt2.jpg   Moser 12-bolt rear end w/brakes-moser_12-bolt_pinion.jpg
Old Dec 21, 2013 | 05:46 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Moser 12-bolt rear end w/brakes
PM sent.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
